HID headlights in the pods for Neo914, Pop-up headlights are not in the plans.. |
neo914-6 |
Jul 21 2005, 01:26 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Maybe Saturn coupes may have been the last to get the word... <!-- emo&:screwy: -->(IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)<!-- endemo -->
As I have said before, the "signal" light pods are a unique characteristic of the 914 design. Making them house headlights will give them a higher purpose than signaling and join the modern "smaller" lighting trend. This and using the existing headlight space where the radiators will mount are why I chose this location. Legal? We'll see if they figure it out... <!-- emo&:lol: -->(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)<!-- endemo --> the "rise and fall" of pop-up headlights: Attached image(s) |
neo914-6 |
Jul 31 2005, 12:55 AM
Haven't found anything here to get me in legal trouble, the bottom of the signal lense is 22". Besides, I will make them look "factory". Maybe NHTSA has more restrictions.. Vehicle Code Headlamps on Motor Vehicles 24400. (a) During darkness, every motor vehicle other than a motorcycle, shall be equipped with at least two lighted headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches. ((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) This section shall become inoperative on July 1, 2005, and, as of January 1, 2006, is repealed, unless a later enacted statute that is enacted before January 1, 2006, deletes or extends the dates on which it becomes inoperative and is repealed. Amended Ch. 13, Stats. 1991. Effective February 13, 1991. Amended and repealed Sec. 1, Ch. 415, Stats. 2004. Effective January 1, 2005. Repeal operative January 1, 2006. The 2004 amendment added the italicized material. NOTE: The preceding section becomes inoperative on July 1, 2005, at which time the following section becomes operative. The preceding section is repealed January 1, 2006. 24400. (a) During darkness and inclement weather, a motor vehicle, other than a motorcycle, shall be equipped with at least two lighted headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches. ((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) As used in subdivision (a), "inclement weather" is a weather condition that is either of the following: (1) A condition that prevents a driver of a motor vehicle from clearly discerning a person or another motor vehicle on the highway from a distance of 1,000 feet. (2) A condition requiring the windshield wipers to be in continuous use due to rain, mist, snow, fog, or other precipitation or atmospheric moisture. © This section shall become operative on July 1, 2005. Added Sec. 2, Ch. 415, Stats. 2004. Effectve January 1, 2005. Operative July 1, 2005. Vehicle Code Use of Multiple Beams24409. Whenever a motor vehicle is being operated during darkness, the driver shall use a distribution of light, or composite beam, directed high enough and of sufficient intensity to reveal persons and vehicles at a safe distance in advance of the vehicle, subject to the following requirements and limitations:(a) Whenever the driver of a vehicle approaches an oncoming vehicle within 500 feet, he shall use a distribution of light or composite beam so aimed that the glaring rays are not projected into the eyes of the oncoming driver. The lowermost distribution of light specified in this article shall be deemed to avoid glare at all times regardless of road contour. ((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Whenever the driver of a vehicle follows another vehicle within 300 feet to the rear, he shall use the lowermost distribution of light specified in this article.Amended Ch. 37, Stats. 1965. Effective September 17, 1965. Vehicle Code Upper and Lower Beam24407. Multiple-beam road lighting equipment shall be designed and aimed as follows: (a) There shall be an uppermost distribution of light, or composite beam, so aimed and of such intensity as to reveal persons and vehicles at a distance of at least 350 feet ahead for all conditions of loading. ((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) There shall be a lowermost distribution of light, or composite beam so aimed and of sufficient intensity to reveal a person or vehicle at a distance of at least 100 feet ahead. On a straight level road under any condition of loading none of the high intensity portion of the beam shall be directed to strike the eyes of an approaching driver. Amended Ch. 547, Stats. 1963. Effective September 20, 1963. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:38 PM |
