white car project, the survivor |
targa72e |
Apr 29 2021, 02:01 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I have started working on a car a purchased last year. Its low mileage and is cleaning up very nicely. I thought I would take some pictures as I work thru this project.
I did not need another car but a 73 came up for sale last year and when I went and looked at it and it was rust free so purchased it on the spot. When went to picked it up and drive home the next day I got the full story. Two owner car, documented 83K miles (Porsche dealer stamps in maintenance book) it had only been driven about 1K miles in the last 20 years. It has a issue where it will not stay in 4th gear and that apparently limited driving. Because of many oil leaks and the engine is very well marinated with oil and will need a full reseal. Fuel injection works great and the car is very original. Its too nice to cut up and do a -6 conversion so I will fix the tranny and reseal the engine drive it a little and probably sell it to fund other projects. Pics before cleaning. This is after washing and buffing. You can see quite a color difference. When I pulled the rockers off all the screws, washers and spacers looked like they were factory and had not been touched. john |
targa72e |
Sep 21 2021, 10:53 PM
Have not updated in a while. I pulled the engine as it was leaking everywhere and I needed to se what was up with transmission not staying in gear in 4th. I am resealing the engine with all new gaskets and seals. Transmission will be gone tru as well. This has given me the opportunity to do some underside cleaning. Underside cleans up well. I think the brown is the original cosmoline (assuming 914 were coated like 911's). Soap and water does not remove brown but brake cleaner does.
Muffler heat shield even looks nice. seam sealer that fell of trunk floor has not burned off heat shield. Drivers side a little more grungy from tranny leak. Not sure what the thought process was on applying undercoating on the floor pan. john Not sure why the pics below are double posted Attached image(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 02:53 PM |
