white car project, the survivor |
targa72e |
Apr 29 2021, 02:01 PM
Member Group: Members Posts: 262 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I have started working on a car a purchased last year. Its low mileage and is cleaning up very nicely. I thought I would take some pictures as I work thru this project.
I did not need another car but a 73 came up for sale last year and when I went and looked at it and it was rust free so purchased it on the spot. When went to picked it up and drive home the next day I got the full story. Two owner car, documented 83K miles (Porsche dealer stamps in maintenance book) it had only been driven about 1K miles in the last 20 years. It has a issue where it will not stay in 4th gear and that apparently limited driving. Because of many oil leaks and the engine is very well marinated with oil and will need a full reseal. Fuel injection works great and the car is very original. Its too nice to cut up and do a -6 conversion so I will fix the tranny and reseal the engine drive it a little and probably sell it to fund other projects. Pics before cleaning. This is after washing and buffing. You can see quite a color difference. When I pulled the rockers off all the screws, washers and spacers looked like they were factory and had not been touched. john |
targa72e |
Feb 21 2022, 11:03 PM
Great progress with the cleanup, any news with the eng/tranny? As you can tell from pics the engine and tranny were removed. Engine got decreased (very well marinated) and received all new gaskets , seals, engine mounts, etc.. Debated what to do with engine tin as there was some surface rust. I elected to just clean it as many of the factory markings were still in good condition. Transmission was also de-greased and inspected. The transmission would not stay in 4th gear, this was the reason I was told the car was not driven much for 20+years. Inspected and then replaced most of the syncros (5th was good and reused), dog teeth and shift selectors. 1st was not good and 4th was very bad (part of the reason it would no stay in gear). Resealed and re-installed and adjusted shifter, as set up it would not go fully into 4th, probably reason 4th was damaged.. So far no leaks from engine or tranny and runs and shifts good. I had one mess up in cleaning some of the heat exchanger ducting. The parts that were painted grey were in good shape but really layered in grease. I used to aggressive a cleaner and stripped the paint. Had to repaint grey. john |
Lo-Fi Version | Time is now: 10th May 2024 - 03:01 AM |
