Dash front seal mounting? |
bkrantz |
Apr 29 2021, 08:57 PM
914 Guru Group: Members Posts: 7,773 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Do I have this facing the right way? Seems like it will stick out as far as the butyl strip for the windshield.
Attached thumbnail(s) |
bkrantz |
Apr 30 2021, 07:35 AM
Any comments?
76-914 |
Apr 30 2021, 08:55 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Damn if I can remember. I only know that I installed it backwards then complained it was poorly made. (IMG:style_emoticons/default/headbang.gif) A year later I flipped it and discovered how wrong I'd been and what a great seal 914rubber had produced. It's easy to install/remove that seal with the windshield in place. (IMG:style_emoticons/default/beerchug.gif)
9146GUY |
Apr 30 2021, 09:12 AM
Member Group: Members Posts: 112 Joined: 29-November 15 From: Central Ohio Member No.: 19,420 Region Association: Upper MidWest |
Looks to me like you have the rubber installed in the wrong position. Move it one groove to the right in the picture
ndfrigi |
Apr 30 2021, 09:34 AM
Advanced Member Group: Members Posts: 2,930 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
If I remember that is correct and I installed mine after the windshield was installed. That front lip of the seal will face up leaning the windshield. In addition, if there is moist from inner side of the windshield, it will just slide towards the top of dash instead of going underneath that can cause rust.
For sure someone from 914rubber will give the exact answer. |
bkrantz |
Apr 30 2021, 08:07 PM
Mikey914 |
May 1 2021, 11:48 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Do I have this facing the right way? Seems like it will stick out as far as the butyl strip for the windshield. The direction on the seal is correct. You will need the corner pillar pieces installed to put it in properly. You will need to notch the ends to accommodate the trim part. I cut the piece about 1/8 longer than needed, put both ends in and overcenter it. It will push down and stay in place. -Mark |
Lo-Fi Version | Time is now: 24th May 2024 - 07:44 AM |
