QUOTE(bkrantz @ Apr 29 2021, 07:57 PM)
Do I have this facing the right way? Seems like it will stick out as far as the butyl strip for the windshield.
The direction on the seal is correct. You will need the corner pillar pieces installed to put it in properly. You will need to notch the ends to accommodate the trim part. I cut the piece about 1/8 longer than needed, put both ends in and overcenter it. It will push down and stay in place.
-Mark
