Finally behind the wheel!, New to me BB is finally drivable |
robkammer |
May 5 2021, 10:37 AM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Today I had my second round of 'shake the bubbles out' drive to get some solid brake pedal feel. Still not there but it feels likeI'm making progress.
A few other observations now that I have some seat time, thoughts and input would be welcome. The temp gauge is very slow to move up, and when it's up and steady its well in the higher ranger, almost past the M in temp. The car does not smell hot so I'm not sure if this is normal. The voltage gauge reads 12 volts for the first 20 minutes or so and then drops down to about 10. Then, when I apply the brakes it drops to about 8, and with a turn signal on it bounces with the turn signal. I still have issues with the brakes but I am optimistic the supplier will stand behind their restoration. Any suggestions where to start looking for the faulty ground r or poor connections for the gauge issues? And it's a real blast to drive on such skinny little tires! Thanks in advance! |
flipb |
May 5 2021, 10:45 AM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
The voltmeter is a very simple circuit. You can see when your brake lights or turn signals are on. I sometimes glance at it to make sure my brake lights are coming on at the right point in the pedal travel. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 12:33 PM |
