Car horn |
Car horn |
partwerks |
May 5 2021, 07:00 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath?
bdstone914 |
May 5 2021, 09:04 PM
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath? Yes but that is not usually the problem. There is a set of contact points inside that get corrored. You have to drill out the rivets and take the cover off to a cess them. |
partwerks |
May 5 2021, 09:18 PM
The horn on a 1975. Can those nuts be removed, so the two terminals can be cleaned underneath? Yes but that is not usually the problem. There is a set of contact points inside that get corrored. You have to drill out the rivets and take the cover off to a cess them. The earlier set I have, has rivets, but my later one does have any rivets. Almost looks like it is crimped on around the edges, similar to the gauges? As of a year ago, it worked, and so as a last resort, I was going to see if that would help. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:07 PM |
