914 2.0 1973, fuel tubes |
theghoul |
May 11 2021, 01:38 AM
Newbie Group: Members Posts: 5 Joined: 5-April 21 From: cleveland ohio Member No.: 25,401 Region Association: None |
Hi! working on the 914 73 2.0 to return it to fuel injection from the single carb- have one of the dual fuel tubes but other one is broken and I do not have all the peices to reweld- if anyone has one I can purchase I would appreciate it! thanks, bob
Spoke |
May 11 2021, 03:42 AM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Check with Tangerine Racing. They have complete sets for sale. I purchased a set when going from single carb back to FI. |
ChrisFoley |
May 11 2021, 05:31 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm sure I have some spare fuel rail pieces, but its not something I ordinarily sell. They only rarely need replacing.
Most anyone who's disassembled 914 engines probably has a few of them hanging around. |
rfinegan |
May 11 2021, 06:49 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Pm me, I am sure I have one you can have...Just want to make sure we
are talking about the same part... -Robert |
rfinegan |
can you post a pic of what you need?
theghoul |
May 20 2021, 10:31 PM
bdstone914 |
May 20 2021, 11:17 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi! Hope to provide pix of the tubes I need - not sure if "fuel tube" is the proper name - has 2 sets of intake tube for vaporized fuel - lets see if I can provide the picture! thanks, - you can email me for that at bobtheatre@aol.com -thanks, theghoul . @theghoul They are called fuel rails. I have them. Which one do you need? The one pictured is a drivers side. The oassenger side does not have the test port. It will hit the MPS. Mine are replated. I also have sets of replated injector hokd down brackets. |
914sgofast2 |
May 21 2021, 12:04 AM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Do you need the intake manifold or the gas line? The photo makes me think you broke one of the large grey intake manifolds if the broken piece is in the background of your photo.
Mark Henry |
May 21 2021, 04:07 AM
Do you need the intake manifold or the gas line? The photo makes me think you broke one of the large grey intake manifolds if the broken piece is in the background of your photo. Good eye! Are you trying to make the 3-bolt intake runner/manifold fit a 4-bolt head? It won't work well, the intake ports don't match. You're better off to get the correct intake runner/manifold for the heads you're using. Show us what you're trying to do, I'm sure a member will find you the correct parts for reasonable cost. |
davep |
May 21 2021, 10:14 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If it is a 2.0 3 bolt intake runner (airbox to head) that the injectors mount on to, Then I have an orphan part to sell. If you need 1.7 runners, then I have 6 sets available. Fuel distribution lines I have several sets.
Dave |
theghoul |
May 23 2021, 12:39 AM
Thanks - the one in center of pix is the complete unbroken one- the one on upper right is missing the other tube and that assembly is what I need- thanks, theghoul
rfinegan |
May 23 2021, 06:57 AM
Sorry, I do not have that part for a Djet
davep |
May 23 2021, 07:14 AM
Mark, you have that lone 2.0 runner with you I believe?
@http://www.914world.com/bbs2/index.php?showuser=26 |
Lo-Fi Version | Time is now: 21st May 2024 - 08:41 AM |
