> Oil Pressure Gauge Sender Kit?
BillJ
post May 12 2021, 07:12 AM
Post #21
I recently picked up a oil pressure gauge for my center console and need to get the sender side. Does anyone make a nice kit that works with our type 4s? Have seen a custom setup with using the oil pressure sensor port and creating a "t" to use both and can probably piece that together myself but a plug and play solution would be nice too. I have a VDO gauge that runs from 0-60psi and 0-5 kgf/cm2 and labeled on face with "I" at the 12 o'clock position and "522" at the 2 o'clock position. back has 3 spades.
I would like to preserve the light as well in the dash so having a solution for both is important to me.
Any help appreciated!
BillJ   Oil Pressure Gauge Sender Kit?   May 12 2021, 07:12 AM
bbrock   They used to sell dual pole senders that let you c...   May 12 2021, 07:42 AM
brant   Buy a dual pole sensor You should not really get ...   May 12 2021, 07:45 AM
BillJ   Oh great! So would toss the old single pole s...   May 12 2021, 07:54 AM
FlacaProductions   Here's the dual pole - and while they sell it,...   May 12 2021, 07:57 AM
BillJ   Definitely interesting. They also sell a splitter...   May 12 2021, 08:14 AM
mate914   I think some on here use a paintball gun hose. I o...   May 12 2021, 09:15 AM
barefoot   There are threads here that discuss adapting a sho...   May 12 2021, 09:21 AM
914werke   & a way to ground the senders ~   May 12 2021, 10:03 AM
johnhora   BillJ I have this good used VDO made in Germany s...   May 12 2021, 10:24 AM
BillJ   I think I am going to get the predrilled block and...   May 12 2021, 11:34 AM
aharder   I think some on here use a paintball gun hose. I ...   May 12 2021, 06:16 PM
FlacaProductions   I may be doing this install next week and the engi...   May 12 2021, 07:02 PM
BillJ   I may be doing this install next week and the eng...   May 13 2021, 05:16 AM
euro911   Those look like they'd work for great the CHT ...   May 12 2021, 11:40 PM
FlacaProductions   Those look like they'd work for great the CHT...   May 13 2021, 07:47 AM
Highland   Hi @BillJ , thought I'd post a picture of wha...   May 13 2021, 02:26 PM
HansJan   Hi [b]@[url=http://www.914world.com/bbs2/index.p...   May 13 2021, 08:31 PM
BillJ   Thanks a ton for the picture that definitely helps...   May 13 2021, 02:47 PM
aharder   Pictures of my set up for both plus 1 in the engin...   May 13 2021, 09:23 PM
930cabman   I am looking at doing something similar, but hard ...   May 14 2021, 04:59 AM
BillJ   I have read that hard pipe runs the risk of cracki...   May 17 2021, 10:04 AM
BillJ   Are brake lines (928) plug and play or will i need...   May 17 2021, 10:11 AM
IVGUY   Heres the part I used and I fabbed up a mount for ...   May 29 2024, 10:21 PM
BillJ   Hi! That particular 914 now lives with new ow...   May 30 2024, 10:31 AM
IVGUY   Yes i have a small rubber washer under the bracket...   May 30 2024, 06:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:36 AM
