Console Clock, Anyone find a suitable replacement |
mmichalik |
May 13 2021, 09:33 AM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Hey guys,
Has anyone found a suitable console clock replacement that works in our cars? I know that AA had one coming but, it's not available yet and as much as I would like an original, the thought of paying that kind of money appeals to me only as a last resort. Thanks! Mike |
914Sixer |
May 13 2021, 10:25 AM
In the past I have found Audi clock cores that duplicate the 914 clock rear. I have one now but I had to pay $100 for it. Sending it out to NHS or PAS will cost $100 + for the swap out. Then add a new trim ring, plastic lens and and paint arms. You have to be careful about buying Audi clock because there is two versions. Has to be exact match on back.
aharder |
May 13 2021, 10:26 AM
Advanced Member Group: Members Posts: 4,393 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
914Sixer |
May 13 2021, 10:39 AM
52mm size, NOT factory 60mm size.
914werke |
May 13 2021, 10:51 AM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
914forme |
May 13 2021, 10:54 AM
classicautoclock@gmail.com might do the conversion to a full quartz clock movement . He has done over 4000 conversion in the last 25 years. I would check with him and see if he can do 914 size console clock.
Handle classicautoclock on Instagram if you want to look at his work it is spot on. |
mmichalik |
May 13 2021, 03:36 PM
Thanks everyone! I will check these options out as well as a couple of others.
I appreciate the guidance here. Mike |
Lo-Fi Version | Time is now: 18th May 2024 - 07:53 AM |
