Base ride height |
Base ride height |
FJ1200 |
May 15 2021, 05:03 PM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
I just installed new 100# rear springs from 914 rubber. It brought the rear up approx 1.5" someone previously had adjusted the front to match whatever springs the car had. Looking for a baseline front ride height measurement to start with. I have heard a rumor that the rocker should be dead level. Is this true? Do the 914 springs put the rear to stock level? If so I can use the procedure in the manual based on dimensions. Yes I plan to have it aligned after I figure out what I will need for rear shims. Thanks, Dan |
Retroracer |
May 15 2021, 06:34 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
The following yielded great results for me:
http://www.914world.com/bbs2/index.php?act...t&id=363723 Note the recommendation for slight rake... - Tony |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:06 AM |
