Greetings,
I just installed new 100# rear springs from 914 rubber. It brought the rear up approx 1.5" someone previously had adjusted the front to match whatever springs the car had. Looking for a baseline front ride height measurement to start with. I have heard a rumor that the rocker should be dead level. Is this true? Do the 914 springs put the rear to stock level? If so I can use the procedure in the manual based on dimensions. Yes I plan to have it aligned after I figure out what I will need for rear shims.
Thanks,
Dan
