2.0 Injector leaking, Is the FJ67 the way to go? |
FlacaProductions |
May 15 2021, 07:22 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I see that Rock Auto has them for $65.89/each - not bad.
I finally got back to my 914 after 15 months of Covid avoidance. Started it up and let it idle for 10 mins specifically to look for stuff like this and sure enough, one of the injectors was leaking. Luckily, I borrowed an extra from a friend nearby but he wants to keep them for backups - understandable for sure. Put his in and it's dry as a bone - confirming it's the injector itself. I should just go with the FJ67's from Rock and replace all four while I'm in there and ship my old ones off for rebuilding and keep what comes back for backups...right? |
bobboinski |
May 15 2021, 07:49 PM
Member Group: Members Posts: 198 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
Seems like a good plan
http://www.914world.com/bbs2/index.php?showtopic=343970 |
914Sixer |
May 16 2021, 06:20 AM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a rebuilt 2.0 injector if you want to go that route. Sealed in package. Can do picture later.
FlacaProductions |
May 16 2021, 07:46 AM
Hey Mark - thank you - I think i'm going to just go with a full set. Seems that when one goes....
RestoReese |
May 17 2021, 11:58 PM
Newbie Group: Members Posts: 31 Joined: 29-June 19 From: Dallas, TX Member No.: 23,256 Region Association: Southwest Region |
I had all 4 of my OEM injectors rebuilt from https://www.mrinjector.us. $17.50 each and he tests them before and after. Includes new rubber gaskets.
Or, you can try buying the rubber gaskets - 1 large/1 small and see if that stops your leak. |
914-Kazoo |
Jun 3 2021, 02:40 PM
Newbie Group: Members Posts: 45 Joined: 19-August 20 From: Kalamazoo, MI Member No.: 24,609 Region Association: Upper MidWest |
I see that Rock Auto has them for $65.89/each - not bad. I finally got back to my 914 after 15 months of Covid avoidance. Started it up and let it idle for 10 mins specifically to look for stuff like this and sure enough, one of the injectors was leaking. Luckily, I borrowed an extra from a friend nearby but he wants to keep them for backups - understandable for sure. Put his in and it's dry as a bone - confirming it's the injector itself. I should just go with the FJ67's from Rock and replace all four while I'm in there and ship my old ones off for rebuilding and keep what comes back for backups...right? READING THE INFO AT ROCK AUTO, DO THESE INJECTORS INSTALL WITHOUT THE TWO GASKETS? OR DID I MISS SOMETHING |
FlacaProductions |
Jun 3 2021, 05:54 PM
I also ordered the STANDARD MOTOR PRODUCTS SK15 seal kit - comes with the small one for the tip and the bigger one for the body. In other words, you need the seals. The injectors themselves do not come with the seals.
windforfun |
Jun 3 2021, 06:07 PM
Senior Member Group: Members Posts: 1,779 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Hey Mark - thank you - I think i'm going to just go with a full set. Seems that when one goes.... I replaced all of my FIs with genuine Bosch parts. I can't remember where I got them from or how much they cost. How's it going dude? (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 08:25 PM |
