914 Electric Conversion, 914 electric conversion |
AmblerEV |
May 16 2021, 05:03 AM
Newbie Group: Members Posts: 1 Joined: 16-May 21 From: Ambler PA Member No.: 25,550 Region Association: None |
Ambler EV is going to officially unveil our full 914 electric conversion at our grand opening June 5, 207 & 211 South Main Street, Ambler PA. For those of you in the Philadelphia area, stop by and see the future. For those of you outside the Philadelphia area, follow our page on Facebook to see more teasers as the day get closer www.facebook.com/Amblerev. For those of you attempting this yourself, I am happy to talk end specs but questions about components used or design will not be answered (EV West is your source for that). If you are interested in buying a full electric 914 (or converting your 914 roller) so that it can handle level 2 charging, has a range over 200 miles, and will no longer contain any vacuum or 40 year old EFI electronics, stop by or email me at sam@amblerev.com.
914forme |
May 16 2021, 11:47 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
(IMG:style_emoticons/default/welcome.png) *************** Deleted for being rude *******************
@AmblerEV So 200 miles range. Speed improvements? Charing time, and requirements? Weight added or subtracted from the chassis? How has the CG and distribution been moved? Rear Wheel drive, AWD, 4 independent wheel motors. Do I loose the transmission? Do I gain space, regenerative braking? Can I run the wheels separate with input controls to make the car turn better, or in an odd case drive the wheels in opposite direction to build a spinning top 914? Won't need to back in or out of the garage anymore. Everything fit with out cutting, odd welding, and none impressive design like some others I have seen? So many questions come up with out me even wanting to build one. What do you and your company really bring to this experience? What makes you better than an EV West or another shop doing this conversion? BTW (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Even if it is a blurred out teaser shot |
JeffBowlsby |
May 16 2021, 12:54 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 AM |
