Turn Signal does not auto-cancel, Just replace the assembly? |
rbzymek |
May 16 2021, 01:54 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
The (1975) ignition lock began jamming so I have a new ignition lock and switch is on order. I plan to have the lock pins revised to match the old key. I would also like the fix the auto cancel for the turn signal. Just replace it of is there more to it? Thanks!
FlacaProductions |
May 16 2021, 07:37 PM
Senior Member Group: Members Posts: 1,591 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
unless you just happened to be missing the "W" spring and can source one from someone here, it's probably best to just install a new switch. just find one that has the same number of pins as the one you're replacing.
rbzymek |
May 17 2021, 07:13 AM
burlybryan |
May 17 2021, 08:08 AM
Member Group: Members Posts: 102 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
FWIW, not that it pertains to your car. The PO of my car installed a Momo wheel and hub and upon re-assembly, they installed the hub clocked so that it wasn't aligned with the switch tang. I rotated the hub and re-gained auto cancel.
930cabman |
May 17 2021, 08:16 AM
Advanced Member Group: Members Posts: 3,071 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
The self cancelling function can be tricky. Are you running a stock steering wheel? It could be as simple as the ring is not tripping the tang. Or it could be internal to the turn signal switch. In the Alfa Romeo world I have heard of guys rebuilding the turn signal switches and repairing the self cancelling function
Lo-Fi Version | Time is now: 21st May 2024 - 05:39 AM |
