rear suspension, re-assembly questions |
Speedo |
May 17 2021, 03:51 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Bolting back up the rear control arms. Where the front of it attaches to the chassis, shouldn't there be a large flat washer on both sides under the big nut? PET shows a washer on the inside.
Next, how do I determine how many shims to use in my link bearing initial setup. Is there a measurement I can take? I have two 3mm and three 4mm. Be nice to get this dialed in at the start. On illustration 501-00 item #4 is called a stopper. Is that metal or plastic and what does it do? How do I determine what spring weight I have on my rear coilovers? Measure the diameter of the spring steel itself? Thanks! |
bdstone914 |
May 17 2021, 04:55 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Although PET shows a washer i have get to find one one a car and have torn down many.
Most cars need about 5mm of shim. But that de lo ends on many factors including how distorted the rubber bushing are in the comtrol arms. Start with what you have and let the car down. Eye ball it from behund the car untill the camber is about 0 |
Speedo |
May 17 2021, 06:39 PM
Although PET shows a washer i have get to find one one a car and have torn down many. Most cars need about 5mm of shim. But that de lo ends on many factors including how distorted the rubber bushing are in the comtrol arms. Start with what you have and let the car down. Eye ball it from behund the car untill the camber is about 0 Ok...thats going to be tough with the 3 and 4mm shims I have. If I use one 4mm per side I start with a little negative camber. My bushings are new. Can't eyeball it from behind the car...chassis is on a dolly being re-assembled. I looked in my Haynes manual and it shows one washer on the control arm which confirms PET What is the #4 stopper for? PO was an avid autoxer. Spring steel diameter is 12mm on the coilovers...is that stock? |
ClayPerrine |
May 17 2021, 08:47 PM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There should be no washer between the pivot shaft and the body on either end. The bar is serrated on the ends where it contacts the body so it will bite in and keep the bar from turning in the hole. However, there are washers under each nut on the outside of each end.
Hope that helps. Clay |
bdstone914 |
May 17 2021, 09:21 PM
@speedo
And the Schnoor washers on the three bts that hold the outer bracket must be replaced with new ones. |
bdstone914 |
May 17 2021, 09:23 PM
@speedo And the Schnoor washers on the three bts that hold the outer bracket must be replaced with new ones. To change the number of shims you only need the remove one bolt and loosen the other two. |
pilothyer |
May 17 2021, 09:29 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
[quote name='Speedo' date='May 17 2021, 07:39 PM' post='2916660']
What is the #4 stopper for? #4 the stoppers are placed at the top to keep dirt/crud out of the threads. They are easily removed to add lots of penetrating oil to ease removal of the M10 X 55 bolts. |
rgalla9146 |
May 18 2021, 04:28 AM
Advanced Member Group: Members Posts: 4,550 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
On '75-'76 (?) I'm pretty sure there are no 'stoppers' the holes are welded shut. |
Speedo |
May 18 2021, 08:05 PM
So ready to pull the hubs into the control arm rear bearings. Ok to lubricate the inner bearing race and the outside of the hub? Or is it better to be a dry "pressed" fit?
bdstone914 |
May 18 2021, 08:28 PM
So ready to pull the hubs into the control arm rear bearings. Ok to lubricate the inner bearing race and the outside of the hub? Or is it better to be a dry "pressed" fit? @speedo Lube is ok. Make sure you support the inner race of the bearing when you pull in the hub. |
Speedo |
May 19 2021, 09:01 AM
So ready to pull the hubs into the control arm rear bearings. Ok to lubricate the inner bearing race and the outside of the hub? Or is it better to be a dry "pressed" fit? @speedo Lube is ok. Make sure you support the inner race of the bearing when you pull in the hub. Absolutely. Been there...unfortunately. |
Lo-Fi Version | Time is now: 8th May 2024 - 10:52 AM |
