rear suspension, re-assembly questions |
Speedo |
May 17 2021, 03:51 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Bolting back up the rear control arms. Where the front of it attaches to the chassis, shouldn't there be a large flat washer on both sides under the big nut? PET shows a washer on the inside.
Next, how do I determine how many shims to use in my link bearing initial setup. Is there a measurement I can take? I have two 3mm and three 4mm. Be nice to get this dialed in at the start. On illustration 501-00 item #4 is called a stopper. Is that metal or plastic and what does it do? How do I determine what spring weight I have on my rear coilovers? Measure the diameter of the spring steel itself? Thanks! |
Speedo |
May 17 2021, 06:39 PM
Although PET shows a washer i have get to find one one a car and have torn down many. Most cars need about 5mm of shim. But that de lo ends on many factors including how distorted the rubber bushing are in the comtrol arms. Start with what you have and let the car down. Eye ball it from behund the car untill the camber is about 0 Ok...thats going to be tough with the 3 and 4mm shims I have. If I use one 4mm per side I start with a little negative camber. My bushings are new. Can't eyeball it from behind the car...chassis is on a dolly being re-assembled. I looked in my Haynes manual and it shows one washer on the control arm which confirms PET What is the #4 stopper for? PO was an avid autoxer. Spring steel diameter is 12mm on the coilovers...is that stock? |
Lo-Fi Version | Time is now: 30th May 2024 - 05:50 AM |
