rear suspension, re-assembly questions |
Speedo |
May 17 2021, 03:51 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Bolting back up the rear control arms. Where the front of it attaches to the chassis, shouldn't there be a large flat washer on both sides under the big nut? PET shows a washer on the inside.
Next, how do I determine how many shims to use in my link bearing initial setup. Is there a measurement I can take? I have two 3mm and three 4mm. Be nice to get this dialed in at the start. On illustration 501-00 item #4 is called a stopper. Is that metal or plastic and what does it do? How do I determine what spring weight I have on my rear coilovers? Measure the diameter of the spring steel itself? Thanks! |
bdstone914 |
May 17 2021, 09:21 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@speedo
And the Schnoor washers on the three bts that hold the outer bracket must be replaced with new ones. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:13 PM |
