rear suspension, re-assembly questions |
Speedo |
May 17 2021, 03:51 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Bolting back up the rear control arms. Where the front of it attaches to the chassis, shouldn't there be a large flat washer on both sides under the big nut? PET shows a washer on the inside.
Next, how do I determine how many shims to use in my link bearing initial setup. Is there a measurement I can take? I have two 3mm and three 4mm. Be nice to get this dialed in at the start. On illustration 501-00 item #4 is called a stopper. Is that metal or plastic and what does it do? How do I determine what spring weight I have on my rear coilovers? Measure the diameter of the spring steel itself? Thanks! |
bdstone914 |
May 17 2021, 09:21 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@speedo
And the Schnoor washers on the three bts that hold the outer bracket must be replaced with new ones. |
bdstone914 |
May 17 2021, 09:23 PM
@speedo And the Schnoor washers on the three bts that hold the outer bracket must be replaced with new ones. To change the number of shims you only need the remove one bolt and loosen the other two. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:38 PM |
