Cradle Weld Technique?, Rear Trans Support |
FL000 |
May 23 2021, 10:06 AM
Member Group: Members Posts: 395 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I have decided to make a cradle to support my engine and trans, well more for the trans. SBC engine and Audi 01E trans.
Engine already has the Renegade Hybrids support and I plan to run two 1.5” x 0.120 round tube perpendicular to the back to tie into the factory trans mount supports. Most of the designs I see here use a tee weld of sorts, or fillet if I have my terminology correct. Basically tube meets flat plate and it is welded together. I am not an experienced welder by any means, but I wonder if cutting a hole in the plate to allow the pipe to pass through, and welding on both top and bottom is preferred? Good idea? Overkill, bad idea? Thanks (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
mb911 |
May 23 2021, 11:47 AM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have decided to make a cradle to support my engine and trans, well more for the trans. SBC engine and Audi 01E trans. Engine already has the Renegade Hybrids support and I plan to run two 1.5” x 0.120 round tube perpendicular to the back to tie into the factory trans mount supports. Most of the designs I see here use a tee weld of sorts, or fillet if I have my terminology correct. Basically tube meets flat plate and it is welded together. I am not an experienced welder by any means, but I wonder if cutting a hole in the plate to allow the pipe to pass through, and welding on both top and bottom is preferred? Good idea? Overkill, bad idea? Thanks (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) That would help for sure strength wise. Typical weld interface is 30% so your suggestion will help stiffen that joint versus just a levered effect. |
tazz9924 |
May 23 2021, 11:48 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
I have decided to make a cradle to support my engine and trans, well more for the trans. SBC engine and Audi 01E trans. Engine already has the Renegade Hybrids support and I plan to run two 1.5” x 0.120 round tube perpendicular to the back to tie into the factory trans mount supports. Most of the designs I see here use a tee weld of sorts, or fillet if I have my terminology correct. Basically tube meets flat plate and it is welded together. I am not an experienced welder by any means, but I wonder if cutting a hole in the plate to allow the pipe to pass through, and welding on both top and bottom is preferred? Good idea? Overkill, bad idea? Thanks (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) That should be good size tubing for what you are doing, it’s possible you could go .090 but the peanut gallery would know better. Cutting a hole and welding from both sides isn’t necessary. With good penetration you wont have issues. Of course it all depends on your design. A good drawing would be good so we can help you the best! |
Lo-Fi Version | Time is now: 21st May 2024 - 06:04 AM |
