Targa Latch Rebuild |
bkrantz |
May 23 2021, 08:00 PM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
My rear targa latches are pretty sloppy. I see replacements for the latch hook arms. Do these have a tighter fit on the pivots? Are the pivots likely to be worn skinny?
Attached thumbnail(s) |
bandjoey |
May 23 2021, 08:02 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
On top of the rebuild get some vac hose and put it on the anchor pin. This alone will pull the top down really tight
bdstone914 |
May 23 2021, 09:53 PM
My rear targa latches are pretty sloppy. I see replacements for the latch hook arms. Do these have a tighter fit on the pivots? Are the pivots likely to be worn skinny? When i rebuild them i powder coat the pivot pin which builds it up. And i use a push on fastener which digs into the paint and holds better. I have seen the snap rings pop off when install as lateral pressure is applied to the hook from worn pins. @bkrantz Attached thumbnail(s) |
76-914 |
May 23 2021, 10:58 PM
I tried some hose on the pins but it was to large. They need very little build up. I finally settled on a few layers of heat shrink tube over the pin. I think the best solution might be to fill in the slot in the latch with a spot weld then file out a new channel for the pin to rest on. (IMG:style_emoticons/default/beerchug.gif)
Mikey914 |
May 24 2021, 01:42 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are making a full rebuild kit. I will post up some info We’d.
Mark |
bkrantz |
May 24 2021, 07:31 PM
Lo-Fi Version | Time is now: 16th May 2024 - 03:14 AM |
