QUOTE(bkrantz @ May 23 2021, 07:00 PM)
My rear targa latches are pretty sloppy. I see replacements for the latch hook arms. Do these have a tighter fit on the pivots? Are the pivots likely to be worn skinny?
When i rebuild them i powder coat the pivot pin which builds it up. And i use a push on fastener which digs into the paint and holds better. I have seen the snap rings pop off when install as lateral pressure is applied to the hook from worn pins.
@bkrantz
