David Stowers |
Member ![]() ![]() Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None ![]() |
Evening all,
I’m looking for recommendations for the following parts for my 6 conversion. 1, oil tank 2, tinware (fibreglass is fine) 3, flywheel for 901 4, heat exchangers oversize if available 5, quick mount engine mount bar 6, E cams 7, anything else I’ve forgotten! Thanks in advance for your suggestions David |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
you probably don't want to use the quick six engine bars.
they crack and break over time. better to go with a bulk head mount... there are multiple brands. |
flyer86d |
Member ![]() ![]() Group: Members Posts: 468 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States ![]() |
Ben (mb911) can supply the oil tank, heat exchangers, muffler and engine tin. There are a few different mounts available. I got my E cams from Retro Automotive in Claremont, New Hampshire. They are a great resource for all used parts Porsche big to small. They have lots of 914 stuff. I hope this helps.
Charlie |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,954 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Ben (mb911) can supply the oil tank, heat exchangers, muffler and engine tin. There are a few different mounts available. I got my E cams from Retro Automotive in Claremont, New Hampshire. They are a great resource for all used parts Porsche big to small. They have lots of 914 stuff. I hope this helps. Charlie Yes, Ben @MB911 is the go to for conversion parts. |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,260 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Engine mount - maddog OEM style mount
Flywheel - I went with OSC I believe on fleaby |
David Stowers |
Thanks so far guys. Keep the options coming please
lesorubcheek |
Member ![]() ![]() Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States ![]() |
Evening all, I’m looking for recommendations for the following parts for my 6 conversion. 1, oil tank 2, tinware (fibreglass is fine) 3, flywheel for 901 4, heat exchangers oversize if available 5, quick mount engine mount bar 6, E cams 7, anything else I’ve forgotten! Thanks in advance for your suggestions David David, I've been looking into possibly doing a 6 conversion and a few other things come to mind. - oil lines. I think there's a few that are unique to the 914-6. - most aftermarket tanks also need a filler neck and filter mount that are sold separately. - a 911 tachometer or a tach adapter. A 5700 redline just wouldn't look right if using an adapter. I'd have to have the face redone. - oil temperature and pressure gauge for the 6. Maybe head temp too. - hand throttle control may be handy. - accelerator bellcrank and cable. There's probably numerous ways to connect the throttle linkage, but will likely require some attention whatever the choice. - I think the transmission shift lever may interfere with the 914/6 heat exchangers, so you may have to replace this with one that's straighter. I'm sure there's plenty more items... the more I research into doing it, the longer the list grows. Dan |
Lo-Fi Version | Time is now: 3rd July 2025 - 10:21 AM |
