Thermostat Replacement, Part Fitment? |
StarBear |
May 26 2021, 07:17 AM
Senior Member Group: Members Posts: 1,884 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
74 1.8L question: My thermostat wire is just about broken (1 strand left) so going to replace it. While under there, figure I might replace the thermostat bellows, too, as it's the original one (PN 021119159A).
Ordered a replacement, a Wahler PN 056121113A. Fitment says it fits, but I don't see any attachment bolt thread nor how to attach the wire. Does it have to be modified? Another case of "it should" fit? (IMG:style_emoticons/default/confused24.gif) IMHO, it looks more like a coolant fluid thermostat, without attachment and with sealing O-ring. Of course, my other option for now is just to replace the cable wire and leave well enough alone but would like to carry a spare that COULD, if needed, be used without a machine shop.... Photos (we all know how we LOVE photos): Original type: Replacement: Replacement (Full): |
Shivers |
May 26 2021, 07:20 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
(IMG:style_emoticons/default/biggrin.gif) Hahahahaha!
JeffBowlsby |
May 26 2021, 07:25 AM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
He-he-he-he. It dont fit. Deception.
If your T-stat is functional why replace it? Here is one solution: http://www.awesomepowdercoat.com/Porsche_9...stat_parts.html AA has another that has good reviews. Check Sierra Madre and the other sources. |
StarBear |
May 26 2021, 07:30 AM
Thanks, all! That was fast! (IMG:style_emoticons/default/piratenanner.gif)
Trusted my teener instinct on this one, but RELIED on experts like you. Yes, saw the other AA alternate part, but says it needs a wire attachment modifications. Going to keep ole' reliable for now; going for a hot afternoon shakedown cruise to prep for upcoming Northeast Gathering! (IMG:style_emoticons/default/driving.gif) |
Superhawk996 |
May 26 2021, 07:31 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/happy11.gif)
I'm going to assume that you are serious. Just re-use use your original. Cable is easily replaced. Original thermostat is NLA and the aftermarket replacments don't fail safe like OEM is supposed to. Keep OEM as long as the bellows isn't cracked and it's still working. No need for spare thermostat to be carried around. If you're OEM thermostat failed with the cooling flaps closed (very rare) - you could always clip the control wire and volia - the flaps pop open and you're good to go. Warmup will be delayed and the thermostat could then be replaced at earliest opportunity. |
iankarr |
May 26 2021, 07:55 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
this ⬆ |
bbrock |
May 26 2021, 08:09 AM
Original thermostat is NLA and the aftermarket replacments don't fail safe like OEM is supposed to. Keep OEM as long as the bellows isn't cracked and it's still working. The Awesome Powdercoat ones linked above do fail safe like the originals. QUOTE No need for spare thermostat to be carried around. If you're OEM thermostat failed with the cooling flaps closed (very rare) - you could always clip the control wire and volia - the flaps pop open and you're good to go. Warmup will be delayed and the thermostat could then be replaced at earliest opportunity. (IMG:style_emoticons/default/agree.gif) If using an OEM style with fail safe, carrying a spare is overkill. |
May 26 2021, 08:55 AM
Cable is the same as a bike derailleur inner cable. Get one at your local bike shop.
StarBear |
May 26 2021, 09:14 AM
Great advice all. Agree, no need to carry a spare. Thanks ever so much!
Still learning after all these years. |
ClayPerrine |
May 26 2021, 11:43 AM
74 1.8L question: My thermostat wire is just about broken (1 strand left) so going to replace it. While under there, figure I might replace the thermostat bellows, too, as it's the original one (PN 021119159A). Ordered a replacement, a Wahler PN 056121113A. Fitment says it fits, but I don't see any attachment bolt thread nor how to attach the wire. Does it have to be modified? Another case of "it should" fit? (IMG:style_emoticons/default/confused24.gif) IMHO, it looks more like a coolant fluid thermostat, without attachment and with sealing O-ring. Of course, my other option for now is just to replace the cable wire and leave well enough alone but would like to carry a spare that COULD, if needed, be used without a machine shop.... Photos (we all know how we LOVE photos): Original type: Replacement: Replacement (Full): You should have ordered a water pump too. (IMG:style_emoticons/default/av-943.gif) |
StarBear |
May 26 2021, 04:48 PM
Jonathan Livesay |
May 26 2021, 06:37 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
If you do need a new bellows the Awesome Powdercoat one is just like the original and so is their mounting bracket. I got one and they are kind of awesome, and yes a Shimano/Sram derailleur cable works just as well as anything else for probably less than 1/2 the bucks. Just don't get a Campagnolo derailleur cable because they cost twice what the real ones do. (IMG:style_emoticons/default/dry.gif)
euro911 |
May 26 2021, 07:58 PM
Cable is the same as a bike derailleur inner cable. Get one at your local bike shop. (IMG:style_emoticons/default/agree.gif) |
rfinegan |
May 27 2021, 09:03 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Has anyone retrofitted alternate (original na)Thermostat or mounted in a remote location? My headers are in the location of the thermostat . I am currently running without a thermostat :-o
Lo-Fi Version | Time is now: 15th May 2024 - 12:53 PM |
