OT 2010 Cayman Headlight Frame, replacing broken fastener/adjuster |
cwpeden |
May 26 2021, 12:23 PM
Off topic - some mid-engine content.
Helping girlfriend do some minor repairs to her 2010, basically providing tools. The fastener for the frame (part 11 in image) is attached to the body and then holds the frame. Does anyone know what kind of torque is on the big nut(19mm)that holds the plastic frame? Does it require Loctite if its not that tight, approx. 5mm thread. PO had been in there and monkeyed with the rig so not sure what stock arrangement is. Any advice is welcome. |
914_teener |
May 26 2021, 12:53 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Off topic - some mid-engine content. Helping girlfriend do some minor repairs to her 2010, basically providing tools. The fastener for the frame (part 11 in image) is attached to the body and then holds the frame. Does anyone know what kind of torque is on the big nut(19mm)that holds the plastic frame? Does it require Loctite if its not that tight, approx. 5mm thread. PO had been in there and monkeyed with the rig so not sure what stock arrangement is. Any advice is welcome. First off that is the wrong PET for a 2010 or 987.2 which is the same as a 987.1 The nut if I recall turns a cam and the whole assembly slides out....a unique design for sure. I can dig up the PET if I have it on another computer. There is no Loctite required for sure. You just have to make sure the light assembly is engaged into the cam and then tighten it to suck the headlight assem. in. Then make sure it is adjusted. edit: Should have read your post on position 11....don't think any locktite is required. Still the wrong PET though. |
cwpeden |
May 26 2021, 01:25 PM
914_teener |
May 26 2021, 01:54 PM
It will become obvious to you when you have it apart. I was nervous the first time I took mine out. It is an feat of engineering for sure and once the three points are in you just tighten it by hand. You don't want to overtighten it for sure as I'm sure you know the cost to replace it is well...very Porsche.
It is way more tricky getting the headlight assembly into the cam mechanisim IMHO, especially the first time. Good luck. |
cwpeden |
May 26 2021, 02:57 PM
Girlfriends car, I'm barely allowed to touch it.
She may ask me for help once she cant figure it out, but that's unlikely. She's pretty resourceful. |
914_teener |
May 26 2021, 05:25 PM
You are a lucky man then. There is nothing like a interdependent woman.
She is a keeper. I happened to be lucky enough to marry a woman like that. Good luck...my advice then is to provide assistance when asked. Hard to do but.....worth it. |
914_teener |
May 26 2021, 05:38 PM
Just a thought....and just a thought.
When I first got my 06 I was very dissapointed in the light output from the stock H lights bulbs. Don't know how she feels about this but if they are not Bi Xenon units I've always thought the stock outputs suck for the Halogens. I ended up replacing them with Hi output Halogen bulbs which don't last as long but the output was twice the stock bulbs. If you have the Bi-Xenon then never mind. This is one aspect of my Cayman that I was disappointed in. Probably the only thing I didn't like. As you may know....the LED kits for these asemblies are big bucks. Anyway...try to keep your mouth shut. |
Front yard mechanic |
May 26 2021, 08:16 PM
Senior Member Group: Members Posts: 1,165 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Girlfriends car, I'm barely allowed to touch it. She may ask me for help once she cant figure it out, but that's unlikely. She's pretty resourceful. My girlfriend wouldn't let me touch it so I got a new girlfriend (IMG:style_emoticons/default/smlove2.gif) |
KELTY360 |
May 27 2021, 11:32 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
[/quote]
My girlfriend wouldn't let me touch it so I got a new girlfriend (IMG:style_emoticons/default/smlove2.gif) [/quote] Doesn’t sound like she was really your girlfriend. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 09:21 AM |
