QUOTE(cwpeden @ May 26 2021, 11:23 AM)
Off topic - some mid-engine content.
Helping girlfriend do some minor repairs to her 2010, basically providing tools.
The fastener for the frame (part 11 in image) is attached to the body and then holds the frame.
Does anyone know what kind of torque is on the big nut(19mm)that holds the plastic frame?
Does it require Loctite if its not that tight, approx. 5mm thread.
PO had been in there and monkeyed with the rig so not sure what stock arrangement is. Any advice is welcome.
Click to view attachmentFirst off that is the wrong PET for a 2010 or 987.2 which is the same as a 987.1
The nut if I recall turns a cam and the whole assembly slides out....a unique design for sure. I can dig up the PET if I have it on another computer. There is no Loctite required for sure. You just have to make sure the light assembly is engaged into the cam and then tighten it to suck the headlight assem. in. Then make sure it is adjusted.
edit: Should have read your post on position 11....don't think any locktite is required. Still the wrong PET though.
