914/6 build thermostat recommendation? |
Tdskip |
May 29 2021, 06:48 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning, hope everyone had a good week.
Nudging then 3.2/6 build forward and wanted to see what thermostat people recommend for a front mounted oil cooler. Thanks! |
Mark Henry |
May 29 2021, 07:08 AM
Original guys use the Porsche T-stat, but it's spendy and has Cohline threads so you have to use the expensive Cohline hose and fittings.
Other use the -12 AN mocal t-stat, with AN hose and fittings. For AN there's other brands of t-stats available, but I'd stick with a known name brand. |
ClayPerrine |
May 29 2021, 07:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Mocal also make a t-stat with 22mm metric threads so you can put the same factory Porsche fittings that screw into the oil cooler on them. Then you can run the Cohline fittings on the ends of the lines.
Tdskip |
May 29 2021, 09:06 AM
May 29 2021, 10:34 AM
roblav1 |
May 29 2021, 11:08 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I used the Impoved Racing aluminum version. So far so good.
Tdskip |
May 29 2021, 01:21 PM
Thanks for the responses, ordered!
Lo-Fi Version | Time is now: 21st May 2024 - 03:51 PM |
