Tdskip
May 29 2021, 06:48 AM
Good morning, hope everyone had a good week.
Nudging then 3.2/6 build forward and wanted to see what thermostat people recommend for a front mounted oil cooler.
Thanks!
Mark Henry
May 29 2021, 07:08 AM
Original guys use the Porsche T-stat, but it's spendy and has Cohline threads so you have to use the expensive Cohline hose and fittings.
Other use the -12 AN mocal t-stat, with AN hose and fittings.
For AN there's other brands of t-stats available, but I'd stick with a known name brand.
ClayPerrine
May 29 2021, 07:57 AM
Mocal also make a t-stat with 22mm metric threads so you can put the same factory Porsche fittings that screw into the oil cooler on them. Then you can run the Cohline fittings on the ends of the lines.
Tdskip
May 29 2021, 09:06 AM
roblav1
May 29 2021, 11:08 AM
I used the Impoved Racing aluminum version. So far so good.
Tdskip
May 29 2021, 01:21 PM
Thanks for the responses, ordered!
