185/65/15 with 7x15 Cookies |
Tdskip |
Jun 1 2021, 06:28 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Anyone running this combo?
Jun 1 2021, 07:03 PM
Why?
That would be a very narrow tire with 7's. Ricer Porsche? |
IronHillRestorations |
Jun 1 2021, 07:04 PM
I’d probably go with 205/60’s on 7”s
fixer34 |
Jun 1 2021, 07:07 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I'm thinking the same. I've had 185/70-15's on stock steelies on my -6 since day one. Seem to fit and handle well. Have just about a finger's gap between the tire and rear fender lip.
914Sixer |
Jun 1 2021, 07:13 PM
What's the offset on the 7 inch wheels? Most 7" wheel/tire combo's do not fit with out wheel well modifications.
Tdskip |
Jun 1 2021, 08:53 PM
Thanks for the responses. Asking because my other 914 with 205’s feels over-tired.
Looks like I should put those on my Fuchs. |
horizontally-opposed |
Jun 1 2021, 09:06 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
185/70R15 on 15x7 Fuchs are common (and were in period), so not sure this would be a problem?
You're a bit low on OD, but not hugely so, as a 195/65R15 would be back up to the right OD. If the tire maker lists 185/65R15 as approved up to a 7-inch wheel, I might try it. Quick search of tires in 185/70 and 185/65 shows rim width minimums of 4.5 to 5.5, and maximums of 6 to 7 inches. Definitely worth checking. Odd that Vredestein approves wider wheels than Pirelli and Riken. |
Racer |
Jun 2 2021, 04:55 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
What's the offset on the 7 inch wheels? Most 7" wheel/tire combo's do not fit with out wheel well modifications. 7x15 Cookies are ET 23.3, just like 7x15 Fuchs (excluding 911R 7x15s) .In period, 185/70 and up to 215/60 were common tires for the 7x15 wheel. Balloon tires compared to today. I've always thought a 195/60-15 looked good on a 914. A balance between the low 50 series and the balloon 70-80 series of the day. Likely not an overly popular choice (185/65-15) but go with what you want or what is available. |
Mayne |
Jun 2 2021, 06:01 AM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Tdskip |
Jun 2 2021, 07:09 AM
garrettlee2 |
Jun 2 2021, 07:59 AM
Member Group: Members Posts: 158 Joined: 8-September 12 From: riverside ca Member No.: 14,901 Region Association: None |
I’ve been thinking the same thing about putting narrow tires on my car. It has more grip then I want. I want it to be a little loose to have fun at a lower limit, maybe even some over stead. Does anyone have experience with a stock 914? Does it have body role? And will tall side walls allow it to move?
Racer |
Jun 2 2021, 08:05 AM
My last /4 had two sets of wheels.
4-bolt fuchs with Toyo RA1s in 205-50-15 4-bolt Mahles with vredestein 165-15. This made for an obvious night/day difference in ride quality and cornerning ability. Both were fun.. but the RA1s were fast. Sharp turn in. No sidewall wallow. Just quick directional change and large quantities of drip in the dry. The 165s were fun because the threshold was so much lower and the ride quality was better. They looks period correct and it is kinda funny to see such a narrow tire on a car, especially these days. |
Tdskip |
Jun 2 2021, 04:28 PM
Thanks for all of he responses and considerations. Appreciate the feedback gentlemen.
wonkipop |
Jun 3 2021, 03:47 AM
Advanced Member Group: Members Posts: 4,296 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I’ve been thinking the same thing about putting narrow tires on my car. It has more grip then I want. I want it to be a little loose to have fun at a lower limit, maybe even some over stead. Does anyone have experience with a stock 914? Does it have body role? And will tall side walls allow it to move? i have a 1.8 74, it was overtyred due to limited options in the 90s. b f goodrich T/A 195 whatever profile. horrible. i tyred up with 165 michelin XAS about a year ago. i love it. it rolls into corners and i guess it slides, it feels like it. for sure this is a softer compound that whatever they used in the 60s/70s. depends what you have. a wimpy 1.8 is just right on a very good quality skinny. i'm really digging it. going to take it to skid pan soon and find out all about it. but i think its very good. i am dead certain what i have is a car that slides a bit, rather than gripping and gripping way beyond what it can power out of - which is where it was before years ago. i know people put vreds on for the look, but they are not in the same league as the michies. i know guys running the michie 165s on 912s and some early 911 long noses that still actually get driven. they said i would not be disappointed. i'm not. but you might want to step up a bit if you are putting out more horsepower. (IMG:style_emoticons/default/beerchug.gif) ,,,,,,,farken well expensive but. |
Tdskip |
Jun 3 2021, 06:34 AM
Thanks for the response, totally agree that too much tire can remove a toss-able / playful driving experience.
Lo-Fi Version | Time is now: 15th May 2024 - 12:23 PM |
