Fuel tube leaking, gas |
Medtner3 |
Jun 5 2021, 12:18 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I have persistent leak at this little tube and it seems to seep gas from either the center of the nut or perhaps from the threads of the nut and fuel tank, I have replaced copper washer and still leaks. Should there be two washers woudl that stop the leak one on either side of the washer that seems welded on to this little tube or just the one washer? the copper washer goes between the tube and bottom of the tank ? what about the filter is there an addiitonal washer?
Should I replace the tube and the nut and new washers again Is there anything like a pipe dope that I could put on the threads that would help? Cannot seem to stop the extremely slow leak. It did not leak for months and then started again. Impossible to tighten the nut further than it is already |
Lo-Fi Version | Time is now: 16th May 2024 - 09:38 PM |
