PO weld job #1 |
PO weld job #1 |
Jwjwjw |
Jun 7 2021, 05:36 PM
Newbie Group: Members Posts: 25 Joined: 22-May 20 From: Hanover, Pa Member No.: 24,296 Region Association: North East States |
What do you think? At least it was creative. Now to fix this. Where would you start?
Jwjwjw |
Jun 7 2021, 05:48 PM
Jwjwjw |
Jun 7 2021, 05:50 PM
Jwjwjw |
Nice isn’t it?
Jun 7 2021, 06:25 PM
So, he welded your trailing arms to the engine mount bar?
Effectively eliminating any sort of suspension travel? (IMG:style_emoticons/default/blink.gif) |
mmichalik |
Jun 7 2021, 06:27 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
So, he welded your trailing arms to the engine mount bar? Effectively eliminating any sort of suspension travel? (IMG:style_emoticons/default/blink.gif) ok, so I was seeing the same thing then. I was scratching my head there for a minute. |
Jun 7 2021, 06:30 PM
I was also wondering what was going on or what they are trying to accomplish.
tygaboy |
Jun 7 2021, 06:32 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I need more info on what, exactly, is going on here. There's no way that could be welded to the engine mount and the trailing arm and prevent things from moving. No way that weld/bracket is strong enough to stop things moving. Does it flex in some magical way? Or is it just being used as the e-brake cable "mount"? Curious minds want to know! |
tygaboy |
Jun 7 2021, 06:34 PM
So, he welded your trailing arms to the engine mount bar? Effectively eliminating any sort of suspension travel? (IMG:style_emoticons/default/blink.gif) Wait a minute @SirAndy , it could have been a "her"! (IMG:style_emoticons/default/lol-2.gif) |
windforfun |
Jun 7 2021, 06:35 PM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Jwjwjw |
Jun 7 2021, 06:55 PM
(IMG:style_emoticons/default/agree.gif) I need more info on what, exactly, is going on here. There's no way that could be welded to the engine mount and the trailing arm and prevent things from moving. No way that weld/bracket is strong enough to stop things moving. Does it flex in some magical way? Or is it just being used as the e-brake cable "mount"? Curious minds want to know! I have no idea what is going on. I assume I should just remove and then start fixing the rust???? |
Jun 7 2021, 07:15 PM
I would do your best to take the chassis back to stock.
Superhawk996 |
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Just sort of makes you scratch your head and say (IMG:style_emoticons/default/WTF.gif)
The small piece of sheet metal over the gaping hole between the long, the inner rear bulkhead and the outer rear bulkhead was a nice touch! For the OP, you're my hero for taking this on! Save another one! |
bkrantz |
Jun 7 2021, 07:27 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
In my experience, PO stupid is like an iceberg. 9/10ths are hidden from sight. Good luck (and keep posting).
Front yard mechanic |
Jun 7 2021, 07:30 PM
Senior Member Group: Members Posts: 1,163 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Take your grinder and pretend it never happened
AZBanks |
Jun 7 2021, 07:38 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Just sort of makes you scratch your head and say (IMG:style_emoticons/default/WTF.gif) The small piece of sheet metal over the gaping hole between the long, the inner rear bulkhead and the outer rear bulkhead was a nice touch! For the OP, you're my hero for taking this on! Save another one! I didn't notice the "rust repair" until you mentioned it. Wow, that is a special kind of POStupid!!! |
Maltese Falcon |
Jun 7 2021, 07:46 PM
Advanced Member Group: Members Posts: 4,645 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
The Ansen (brand) ground grabbers did wonders on eliminating rear wheel hop, under drag racing conditions: but can't figure out this Darwin's stick-welding nightmare on a 914.
Round up the usual grinders + face shields (IMG:style_emoticons/default/smile.gif) |
aharder |
Jun 7 2021, 08:31 PM
Advanced Member Group: Members Posts: 4,390 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
The first thing I would do is replace those Jack Stands....
Heard of too many failures with those. |
930cabman |
Jun 8 2021, 05:17 AM
Advanced Member Group: Members Posts: 3,063 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks like another adventure coming, hold on tight.
rgalla9146 |
Jun 8 2021, 05:28 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
That is to disguise the collapsed rear suspension.....the ultimate used car crime. "Yes sir, it's got the racin' shocks.....real stiff. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:02 AM |
