Jwjwjw
Jun 7 2021, 05:36 PM
What do you think? At least it was creative. Now to fix this. Where would you start?
Jwjwjw
Jun 7 2021, 05:48 PM
I was only able to post one picture?? Have to post at least one move, look for it.
Jwjwjw
Jun 7 2021, 05:50 PM
Jwjwjw
Jun 7 2021, 06:25 PM
So, he welded your trailing arms to the engine mount bar?
Effectively eliminating any sort of suspension travel?
mmichalik
Jun 7 2021, 06:27 PM
QUOTE(SirAndy @ Jun 7 2021, 05:25 PM)
ok, so I was seeing the same thing then.
I was scratching my head there for a minute.
Jun 7 2021, 06:30 PM
I was also wondering what was going on or what they are trying to accomplish.
tygaboy
Jun 7 2021, 06:32 PM
I need more info on what, exactly, is going on here. There's no way that could be welded to the engine mount and the trailing arm and prevent things from moving. No way that weld/bracket is strong enough to stop things moving.
Does it flex in some magical way? Or is it just being used as the e-brake cable "mount"?
Curious minds want to know!
tygaboy
Jun 7 2021, 06:34 PM
Wait a minute
@SirAndy , it could have been a "her"!
windforfun
Jun 7 2021, 06:35 PM
Jwjwjw
Jun 7 2021, 06:55 PM
QUOTE(tygaboy @ Jun 7 2021, 06:32 PM)
I have no idea what is going on. I assume I should just remove and then start fixing the rust????
Jun 7 2021, 07:15 PM
I would do your best to take the chassis back to stock.
Superhawk996
Just sort of makes you scratch your head and say
The small piece of sheet metal over the gaping hole between the long, the inner rear bulkhead and the outer rear bulkhead was a nice touch!
For the OP, you're my hero for taking this on! Save another one!
bkrantz
Jun 7 2021, 07:27 PM
In my experience, PO stupid is like an iceberg. 9/10ths are hidden from sight. Good luck (and keep posting).
Front yard mechanic
Jun 7 2021, 07:30 PM
Take your grinder and pretend it never happened
AZBanks
Jun 7 2021, 07:38 PM
QUOTE(Superhawk996 @ Jun 7 2021, 06:15 PM)
I didn't notice the "rust repair" until you mentioned it. Wow, that is a special kind of POStupid!!!
Maltese Falcon
Jun 7 2021, 07:46 PM
The Ansen (brand) ground grabbers did wonders on eliminating rear wheel hop, under drag racing conditions: but can't figure out this Darwin's stick-welding nightmare on a 914.
Round up the usual grinders + face shields
aharder
Jun 7 2021, 08:31 PM
The first thing I would do is replace those Jack Stands....
Heard of too many failures with those.
930cabman
Jun 8 2021, 05:17 AM
Looks like another adventure coming, hold on tight.
rgalla9146
Jun 8 2021, 05:28 AM
That is to disguise the collapsed rear suspension.....the ultimate used car crime.
"Yes sir, it's got the racin' shocks.....real stiff.
rfinegan
Jun 8 2021, 05:29 AM
NO bolts in the engine mount bar? Is that so the assembly can still pivot with the suspension?
OR are the early bars recesses for the bolts?
Jun 8 2021, 05:48 AM
QUOTE(rfinegan @ Jun 8 2021, 07:29 AM)
If I remember correctly, early bars use recessed Allen heads.
Root_Werks
Jun 8 2021, 08:44 AM
Oh goodness, remove and don't replace.
flyer86d
Jun 8 2021, 03:10 PM
Could they have been trying to support the trailing arm because of a failing or failed inner suspension pickup ear? The chassis looks a little crispy on the drinker side....
Charlie
dlee6204
Jun 8 2021, 04:47 PM
QUOTE(flyer86d @ Jun 8 2021, 05:10 PM)
Charlie
It looks like the inner mount is compromised.
Jonathan Livesay
Jun 8 2021, 05:02 PM
QUOTE(dlee6204 @ Jun 8 2021, 03:47 PM)
Charlie
They welded that on so they wouldn't have to go back to recover the right rear wheel when the swing arm came off.
maf914
Jun 8 2021, 05:12 PM
QUOTE(SirAndy @ Jun 7 2021, 04:25 PM)
Maybe he was trying to turn the engine mount bar into an anti-sway bar?
Oh, wait a minute, the engine mount bar is anchored at each end. Never mind.
What was he trying to do? Did you drive the car with this modification? If so, how did it drive?
wonkipop
Jun 8 2021, 06:50 PM
QUOTE(rgalla9146 @ Jun 8 2021, 05:28 AM)
"great" men think alike.
not saying i'm great but y'know whad i mean
chassis looks like its made of transparent steel - this is after the rarely observed event when the hell hole goes supernova and turns into a black hole?
maybe should not cut bar loose just yet. at least can still be pushed around.
IronHillRestorations
Jun 8 2021, 09:15 PM
Looks like they were trying to break the outer engine mount consoles by torquing out the engine bar
brant
Jun 8 2021, 09:33 PM
QUOTE(dlee6204 @ Jun 8 2021, 04:47 PM)
Charlie
mate914
Jun 9 2021, 05:56 AM
I call those pecker tracks.... Dont remove until you know more.
Matt
dr.tim
Jun 9 2021, 05:57 AM
QUOTE(maf914 @ Jun 8 2021, 05:12 PM)
That is my interpretation. It does have torsional rigidity sufficient to serve as such, but...
there are better ways to do this.
mbseto
Jun 9 2021, 01:26 PM
Well, we can all look at that picture and say, at least I know I am not the sharpest hammer in the bag!
Superhawk996
Jun 9 2021, 02:43 PM
@jwjwjw you should post these pics over at the other DAPO thread. You have a real contender.
http://www.914world.com/bbs2/index.php?sho...11299&st=40
Jwjwjw
Jun 10 2021, 06:14 AM
QUOTE(aharder @ Jun 7 2021, 08:31 PM)
Thanks for looking out for me! All the jacks I saw looked similar. What do u recommend?
Tks Jeff
Shivers
Jun 10 2021, 07:58 AM
QUOTE(Jwjwjw @ Jun 10 2021, 05:14 AM)
Tks Jeff
The pin type has a much lower failure rate. One of the members here had a real bad day with those holding up his car.
Maltese Falcon
Jun 10 2021, 08:37 AM
Tks Jeff
I like this style; 3 welded .250" thick disc-pads on the ground , HD welded construction, pin type.
Just search online for the deal, like: Jegs, Summit, Pegasus Racing
ChrisFoley
Jun 10 2021, 08:48 AM
I've seen some crazy, bad, stupid repair work on 914s,
but that takes it to a whole 'nuther level.
