Help with Seat Belt Hardware |
bkrantz |
Jun 10 2021, 08:08 PM
914 Guru Group: Members Posts: 7,769 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I think I have sorted all the bolts, washers, and bushings to get my seat belts installed, except for the belt end that bolts to the sills on the outboard side of the seats. I have stuff that came off the car (but a mix of PO randomness) and that I collected from other sources.
It looks like the metal bushings fit the belt end tabs best, but the Porsche parts catalog shows plastic bushings. Any guidance? A 73, BTW. Attached thumbnail(s) |
windforfun |
Jun 10 2021, 08:24 PM
Senior Member Group: Members Posts: 1,801 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I think I have sorted all the bolts, washers, and bushings to get my seat belts installed, except for the belt end that bolts to the sills on the outboard side of the seats. I have stuff that came off the car (but a mix of PO randomness) and that I collected from other sources. It looks like the metal bushings fit the belt end tabs best, but the Porsche parts catalog shows plastic bushings. Any guidance? A 73, BTW. By sills do you mean up by your shoulder or down at the floor? |
bbrock |
Jun 10 2021, 09:41 PM
My 73 had the plastic washers. I also learned that the short shoulder bolts go on the inboard side to bolt the receivers to the tunnel. If you use the long bolts there, the driver's side will interfere with the shift rod, causing it to grind and be hard to shift into 4 and 5. Had to learn that one the hard way (IMG:style_emoticons/default/dry.gif)
bkrantz |
Jun 11 2021, 07:19 AM
I think I have sorted all the bolts, washers, and bushings to get my seat belts installed, except for the belt end that bolts to the sills on the outboard side of the seats. I have stuff that came off the car (but a mix of PO randomness) and that I collected from other sources. It looks like the metal bushings fit the belt end tabs best, but the Porsche parts catalog shows plastic bushings. Any guidance? A 73, BTW. By sills do you mean up by your shoulder or down at the floor? By the floor in the sills. |
bdstone914 |
Jun 11 2021, 07:44 AM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@bkrantz
Here is a picture of the order of the hardware. Top pair B pillar Second from top, outer long Third from top reciever to tunnel Bottom, retractor to firefall. Not that Schnooor or wave washers are used. The metal loops go between to two black washers. Original washers are collared whit washers. Attached thumbnail(s) |
dirk2056 |
Jun 11 2021, 10:15 AM
Member Group: Members Posts: 93 Joined: 31-July 17 From: cincinnati/Eastside Member No.: 21,304 Region Association: Middle East |
I would like to send out seatbelts for overall springs belts etc. who do you recommend?
Thanks |
bkrantz |
Jun 11 2021, 07:39 PM
@bkrantz Here is a picture of the order of the hardware. Top pair B pillar Second from top, outer long Third from top reciever to tunnel Bottom, retractor to firefall. Not that Schnooor or wave washers are used. The metal loops go between to two black washers. Original washers are collared whit washers. Thanks very much--makes sense to me now. |
Lo-Fi Version | Time is now: 22nd May 2024 - 06:39 AM |
