adding M calipers, pros and cons |
jims914 |
Jun 22 2021, 07:27 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Hello,
Has anyone have any good input about adding M calipers on front 70 914. Different rotors, thicker pads ? Any pros or cons. any help would appreciated. |
Jun 22 2021, 07:45 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Positive- They have more stopping power (if you need/want it) than stock calipers.
Negative - They only work on 3” 911/914-6 struts and hubs. |
jims914 |
Jun 22 2021, 08:11 PM
Jun 22 2021, 08:18 PM
Hello, Has anyone have any good input about adding M calipers on front 70 914. Different rotors, thicker pads ? Any pros or cons. any help would appreciated. The rear 911 M calipers have a 3in bolt pattern like the 914 4, is there a rotor to use or thicker pad ? M calipers, except for the solid rotor model on 912’s use a vented rotor. To use M calipers on the rear, you need a 911 ebrake ( I believe early works best) and tangerine racing adaptors. And some grinding and welding. |
jims914 |
Jun 22 2021, 08:51 PM
Hello, Has anyone have any good input about adding M calipers on front 70 914. Different rotors, thicker pads ? Any pros or cons. any help would appreciated. The rear 911 M calipers have a 3in bolt pattern like the 914 4, is there a rotor to use or thicker pad ? M calipers, except for the solid rotor model on 912’s use a vented rotor. To use M calipers on the rear, you need a 911 ebrake ( I believe early works best) and tangerine racing adaptors. And some grinding and welding. Sorry you are missing the point. Thanks |
Jun 22 2021, 09:13 PM
Sorry, the point isn’t very clear.
Using rear M on a stock 914 front? Probably not due to rotor & hub spacing. The caliper also uses vented rotors. If it’s some other configuration, probably not that either. 914 & 911 brake parts don’t usually play nice together. |
dhuckabay |
Jun 22 2021, 09:34 PM
Member Group: Members Posts: 223 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest |
Sorry, the point isn’t very clear. Using rear M on a stock 914 front? Probably not due to rotor & hub spacing. The caliper also uses vented rotors. If it’s some other configuration, probably not that either. 914 & 911 brake parts don’t usually play nice together. Have M on the front, like them. Just did a rebuild, hard to get the right pistons. They have a guide rod on the inside. Will say that Sierra Madre sorted it out, after a few failed attempts earlier. From doing a 911 at the same time it looks like the rears are the same. |
Mark Henry |
Jun 23 2021, 05:57 AM
I have vented Alfa Brembos on the fronts with V-calipers, 914/4 calipers with spacers and turned down 911 vented rotors, on the rear.
The wife's 914 has M calipers on the fronts and welded /redrilled hubs with stock brakes on the rear. The project 914 will be getting Alfa Brembos on the fronts as well. |
9146C |
Jun 23 2021, 07:27 AM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
This is a difficult post to follow...(maybe the coffee hasn't kicked in yet...)
The OP's initial question was installing M calipers on the front which was quickly answered. In post #3, OP comes back and asks (I think???) if 911 M rears will work on the front of stock struts (???). It may be helpful if the OP helps refine his question on what the end goal is...ie, street or track/autocross, eliminate brake fade, improved braking due to high HP engine swap, etc. I think it would also be helpful to readers if the OP specifies if this is only an enquiry for front brake upgrade options. Is the OP limited to a budget upgrade and not intersted in upgrading the struts? Just my $0.02... |
larryM |
Jul 5 2021, 11:11 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Lo-Fi Version | Time is now: 19th May 2024 - 02:51 AM |
