jims914
Jun 22 2021, 07:27 PM
Hello,
Has anyone have any good input about adding M calipers on front 70 914.
Different rotors, thicker pads ?
Any pros or cons.
any help would appreciated.
Jun 22 2021, 07:45 PM
Positive- They have more stopping power (if you need/want it) than stock calipers.
Negative - They only work on 3” 911/914-6 struts and hubs.
jims914
Jun 22 2021, 08:11 PM
QUOTE(jims914 @ Jun 22 2021, 06:27 PM)
Hello,
Any pros or cons.
The rear 911 M calipers have a 3in bolt pattern like the 914 4, is there a rotor to use or thicker pad ?
Jun 22 2021, 08:18 PM
QUOTE(jims914 @ Jun 22 2021, 10:11 PM)
Hello,
Any pros or cons.
M calipers, except for the solid rotor model on 912’s use a vented rotor. To use M calipers on the rear, you need a 911 ebrake ( I believe early works best) and tangerine racing adaptors. And some grinding and welding.
jims914
Jun 22 2021, 08:51 PM
QUOTE(mepstein @ Jun 22 2021, 07:18 PM)
Hello,
Any pros or cons.
Sorry you are missing the point.
Thanks
Jun 22 2021, 09:13 PM
Sorry, the point isn’t very clear.
Using rear M on a stock 914 front? Probably not due to rotor & hub spacing. The caliper also uses vented rotors.
If it’s some other configuration, probably not that either. 914 & 911 brake parts don’t usually play nice together.
dhuckabay
Jun 22 2021, 09:34 PM
QUOTE(mepstein @ Jun 22 2021, 08:13 PM)
Have M on the front, like them. Just did a rebuild, hard to get the right pistons. They have a guide rod on the inside. Will say that Sierra Madre sorted it out, after a few failed attempts earlier. From doing a 911 at the same time it looks like the rears are the same.
Mark Henry
Jun 23 2021, 05:57 AM
I have vented Alfa Brembos on the fronts with V-calipers, 914/4 calipers with spacers and turned down 911 vented rotors, on the rear.
The wife's 914 has M calipers on the fronts and welded /redrilled hubs with stock brakes on the rear.
The project 914 will be getting Alfa Brembos on the fronts as well.
9146C
Jun 23 2021, 07:27 AM
This is a difficult post to follow...(maybe the coffee hasn't kicked in yet...)
The OP's initial question was installing M calipers on the front which was quickly answered.
In post #3, OP comes back and asks (I think???) if 911 M rears will work on the front of stock struts (???).
It may be helpful if the OP helps refine his question on what the end goal is...ie, street or track/autocross, eliminate brake fade, improved braking due to high HP engine swap, etc.
I think it would also be helpful to readers if the OP specifies if this is only an enquiry for front brake upgrade options. Is the OP limited to a budget upgrade and not intersted in upgrading the struts?
Just my $0.02...
larryM
Jul 5 2021, 11:11 AM
X2
QUOTE(9146C @ Jun 23 2021, 06:27 AM)
