Vacuum Hose Kit, Anyone other than AA offer one for L-Jet? |
SteveL |
Jun 23 2021, 03:29 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
I am chasing some idle issues, and figure it would be a good idea to just cross off all vacuum lines from the potential cause list, since they are all 20+ years old anyway.
If nobody else offers a kit, does anyone have a list of the sizes I need to order? Thanks |
StarBear |
Jun 23 2021, 04:26 PM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
I am chasing some idle issues, and figure it would be a good idea to just cross off all vacuum lines from the potential cause list, since they are all 20+ years old anyway. If nobody else offers a kit, does anyone have a list of the sizes I need to order? Thanks There is a diagram and list on Jeff bowlsby’s site specific to the 1.8 LJet. It’s different than the others. Also a thread a few weeks ago in Originality Forum, Vaccuum Hoses, with lots of info, including which lines were originally green. |
wonkipop |
Jun 23 2021, 04:35 PM
Advanced Member Group: Members Posts: 4,299 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I am chasing some idle issues, and figure it would be a good idea to just cross off all vacuum lines from the potential cause list, since they are all 20+ years old anyway. If nobody else offers a kit, does anyone have a list of the sizes I need to order? Thanks you will find there are one or two hoses you can't get. this may apply to AA kits as well. One is the line from crankcase ventilation valve to the intake tube from aircleaner. there is another tricky little one from the aux air valve to the intake plenum. If your AAV hose is still reasonable I'd leave it on, this hose can collapse when its replaced with a new line, the original was i believe preformed, very short but pre-bent. i've ended up leaving the original cv hose and aav hose on, both were still ok and sealing, and now 47 years old. a tip is to check your throttle body gasket. that can go hard and cause air leaks i found and a source of some idling issues in mine - it was sealing tight when the engine was cold but as things warmed up with thermal expansion it started to leak. 914 rubber have that one. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:07 PM |
