GB 1 of 2 - Fuel injector Rubber holders - NLA now we have them, $8 for a set of 4 All GB's close July 31st |
Mikey914 |
Jul 8 2021, 11:52 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have got a few calls for these and as I need them too decided to make them. The choice is to try to reuse the old ones and if you go through a few you can get a set, but they aren't as solid as the originals as they have deformed from pressure, heat and time.
Pictures aren't as pretty as they can be but these fit nice. $8 for a set of 4 on GB small and easy to ship. These are in production and will start shipping beginning of next week, if you are having issues with how firmly your injectors are being held in this is your answer, so who needs a set? As I mentioned we are also done with tooling on another item we have been making, but were hand casting - Side marker lenses both clear and amber. There is another thread that will be going for them. I'll put the link here so you can +1 if you want that deal too. That way shipping can be combined. http://www.914world.com/bbs2/index.php?act...=0#entry2929417 (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
DRPHIL914 |
Jul 9 2021, 06:32 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i will take a set
Phil |
Jett |
Jul 9 2021, 08:54 AM
Senior Member Group: Members Posts: 1,640 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I’ll take two sets please
56kabrio |
Jul 9 2021, 08:40 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
I’ll take a set please.
Thanks Mack |
MM1 |
Jul 10 2021, 11:06 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
wonkipop |
Jul 11 2021, 12:23 AM
Advanced Member Group: Members Posts: 4,347 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
might have to get a set too to go with ambers for the stash.
nice that you have remade them. (IMG:style_emoticons/default/beerchug.gif) |
Jack Standz |
Jul 11 2021, 02:51 AM
Member Group: Members Posts: 278 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Two sets please.
Mikey914 |
Jul 26 2021, 08:48 AM
PMs sent to all so for, sorry for the delay on getting these processed and opening it up.
We will keep both GB's gong until July 31st. Thanks again, Mark |
Pappy1975 |
Jul 26 2021, 10:46 AM
Newbie Group: Members Posts: 23 Joined: 19-December 19 From: South Carolina Member No.: 23,745 Region Association: South East States |
I’d like to get a sat of the FI rubber holders and a set of the clear side markers. Please send me the discount codes.
Thanks, David |
jrmdir |
Aug 6 2021, 09:31 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
I'd also like a set of 4 rubber seals. Please PM the code.
Thanks! Ron |
SteveL |
Aug 11 2021, 08:32 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
You are talking about the larger rubber o-ring seals, correct?
I need a set of both the larger seals and the small lower seals. Also, do you have replacement fuel injector hoses (the short lines from fuel rail to injector? Thanks |
Mikey914 |
Aug 14 2021, 11:15 AM
Sorry the Group Buy had closed some time ago. I do have theses here
https://914rubber.com/new-fuel-injector-rubber-holder Got the fuel lines and other goodies here https://914rubber.com/search/?q=Fuel+injector BTW the difference on the kit version is it has new nuts and washers. No pictures is up yet. Mark |
Lo-Fi Version | Time is now: 28th May 2024 - 10:50 AM |
