Any recommendations on a decent welder? |
Jul 10 2021, 06:12 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I need to weld a few bits and bobs around the 914, nothing structural.
I've done my fair share of Mig so i'm not new to welding per se but i have no idea what brands are good and why. Any recommendations would be greatly appreciated. (IMG:style_emoticons/default/idea.gif) |
bdstone914 |
Jul 10 2021, 06:39 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
930cabman |
Jul 10 2021, 06:53 PM
Advanced Member Group: Members Posts: 3,105 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Lincoln 140 MIG. 110 volts and will do anything required on out 914's and more. Make sure you use only solid wire and don't forget to change the polarity internally
tygaboy |
Jul 10 2021, 07:45 PM
914 Guru Group: Members Posts: 5,300 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I have a Miller 211 AutoSet. Mine is maybe 10 years old. It runs on 220 or 110. You just swap the end of the cord to the plug type you're going to use and plug it in. It takes care of the rest.
I recently got to use @Markhoward Mark's brand spankin' new version of the 211. It is a GREAT unit. Yes, with the 220 capability you're way over what you may need to do 914 sheet metal. But it's a wonderful unit that will likely never be outgrown. And just FYI, while I have a Miller MIG, my TIG is a Lincoln. Just so you know I'm not tied to a particular brand. If you'd like, come up sometime and you're welcome to test it out, see what you think, etc. |
bkrantz |
Jul 10 2021, 07:53 PM
914 Guru Group: Members Posts: 7,778 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have been mostly happy with my Hobart MIG, 120 V. The unhappy times came when I tried to weld stock that was too thick, say .125 or more.
Last year, I added an Eastwood TIG, mostly for thicker stuff. I am still learning, but my son has gotten great results. |
cary |
Jul 10 2021, 09:15 PM
MillerMatic 141
Maltese Falcon |
Jul 10 2021, 11:54 PM
Advanced Member Group: Members Posts: 4,672 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Our shop has been Miller equipped (.035 wire) migs for decades. Probably less than $500.00 in maintenance + repairs in the last 20 years...great machines ! For your non-mfg needs, there are good choices for home/ hobby use. Find a dealer like AirGas and check out their showroom (IMG:style_emoticons/default/welder.gif)
mb911 |
Jul 11 2021, 08:25 AM
914 Guru Group: Members Posts: 6,860 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hobart handler is the best bang for the buck and under $500. I have used enough of them for 25 years and they are about the best hobby name brand welder out there for under $600.
Hobart is owned by Miller. Also keep in my line of work I get to use every brand and the latest and greatest. The Lincoln mp210 is amazing, The new MP Miller machines are plagued with board issues. The Lincoln boards are made and epoxied in cleavland so they are US made. If the budget is higher say $2500 the best unit on the market right now for multiprocess with AC TIG capabilities I would choose the ESAB 205IC Rebel. Again depends on your needs. Stick with Hobart,Miller, Lincoln,ESAB over any of the other brands for sure. The luxury I have is being exposed to everything and use them all. I am impartial just want the best working/quality machine for the money. I do national training for Lincoln but don't work directly for them. They have some fantastic equipment but so do the other brands I mentioned. |
worn |
Jul 11 2021, 05:21 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I need to weld a few bits and bobs around the 914, nothing structural. I've done my fair share of Mig so i'm not new to welding per se but i have no idea what brands are good and why. Any recommendations would be greatly appreciated. (IMG:style_emoticons/default/idea.gif) It seems like your question requires a bit more. If you want to satiate the craftsman within, then it is money very well spent going the higher roads that Ben ay offer guidance for. On tother hand, MIG welding in any form is an honest to God miracle and Hobart Handlers offer bang and buck. Good luck. Remember, you can be very popular welding bookcases and frying pans. |
Chaznaster |
Jul 11 2021, 07:04 PM
Member Group: Members Posts: 300 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Hobart 210 MPV. Solid machine for under $1k. Have had it for two years and no issues.
worn |
Jul 11 2021, 07:57 PM
cary |
Jul 11 2021, 08:29 PM
Hobert Handler 140. $529 on Amazon.
Might buy one to set up as a silicon bronze mig machine. @mb911 Ben thoughts ? |
Montreal914 |
Jul 11 2021, 10:48 PM
Senior Member Group: Members Posts: 1,568 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I will not pretend I know how to weld (IMG:style_emoticons/default/rolleyes.gif)
But I got one of those Lincoln 140 (110V) on CL about 10 years ago, and as mentioned by another member, it has been good for the work on my car. I use it with Argon mix (75-25) and .023" or .030" wire. You do need a different roller for the wire. The machine came with a 0.030" and I got a 0.025" on Amazon. If I recall I paid $250 for my machine which was very clean, and still is. I am always on a budget... (IMG:style_emoticons/default/headbang.gif) Just saw this: https://sfbay.craigslist.org/nby/tls/d/sant...7348599608.html Good luck! (IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Jul 12 2021, 06:17 AM
Hobert Handler 140. $529 on Amazon. Might buy one to set up as a silicon bronze mig machine. @mb911 Ben thoughts ? I have done 30 seconds of silicon bronze MIG.. it's more a body shop type of thing and not used in manufacturing for the most part so not in my wheel house.. I am sure the Hobart would work just fine for it. |
Unobtanium-inc |
Jul 12 2021, 07:00 AM
Advanced Member Group: Members Posts: 2,212 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Our Miller died a little over a year ago, it served us well, so we bought one of the Vulcan ones from HF, it is light years ahead of my 15 year old miller. It can also do TIG, which I plan to try out soon, but the MIG is very smooth, almost like laying caulk. I was impressed for the money. It also takes a lot of the guesswork out of the settings because you type in what you're welding, thickness, etc and it does the settings. It's also nice on metal that isn't the best, believe it or not, we weld some rusty shit around here.
https://www.harborfreight.com/omnipro-220-i...nput-63621.html Attached thumbnail(s) |
Andyrew |
Jul 12 2021, 07:52 AM
I contemplated between the Vulcan and the Titanium at HF.
I ended up going with the Titanium multi process unit which is a mig/tig/stick/spool gun. All told it was about 1k for everything with a coupon and I only have one machine in the garage. Lovely welder. After 20 years with my little lincoln, this new welder was just awesome. You can not go wrong with this guy. Spend the rest of the money on a warranty, consumables, cart, and a 60+cf tank. Probably be ~ $800 all in. https://www.harborfreight.com/mig-140-profe...nput-64804.html If you have 220 in your shop grab the 220/110 version for more power. Best part about this welder is its only 25lbs, so moving it around the shop or taking it to your buddies is not a big deal. No you dont need a bigger welder for a home shop guy. |
rjames |
Jul 12 2021, 10:37 AM
I'm made of metal Group: Members Posts: 3,939 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I've been extremely happy with my Miller.
Consider picking up a used welder. I got it and a tank off of Craigslist for 1/2 of what it would've cost new, and it's been going strong for ~15 years. |
gereed75 |
Jul 12 2021, 01:35 PM
Senior Member Group: Members Posts: 1,248 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I was fortunate to pick a Hobart Handler locally on CL along with a gas cylinder. I am a rank amateur but love to weld and the welder seems great. Very capable for anything I have needed to do to date including some heavier gage stuff (brackets and similar). I am able to make some decent welds even on thin stock when the metal is well prepped and my technique is sound.
I almost was hoping that the guys buying HF would say that they are crap, but I am not surprised at the positive review. I have seen the progression of increasing quality as Asian sources have entered the US market, first with the Japanese, then Taiwan, now china. I don't deny them credit, I am just loathe to see what it has done to our culture and hope that it somehow works out for the better. |
mb911 |
Jul 12 2021, 01:47 PM
I was fortunate to pick a Hobart Handler locally on CL along with a gas cylinder. I am a rank amateur but love to weld and the welder seems great. Very capable for anything I have needed to do to date including some heavier gage stuff (brackets and similar). I am able to make some decent welds even on thin stock when the metal is well prepped and my technique is sound. I almost was hoping that the guys buying HF would say that they are crap, but I am not surprised at the positive review. I have seen the progression of increasing quality as Asian sources have entered the US market, first with the Japanese, then Taiwan, now china. I don't deny them credit, I am just loathe to see what it has done to our culture and hope that it somehow works out for the better. (IMG:style_emoticons/default/agree.gif) I know we all buy items from world wide companies I just try to support US made items when I can. I am also a big buy local guy if I can |
roblav1 |
Jul 12 2021, 03:30 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
TiG only... I like my old Synchrowave 200, but it runs only on 220v. For 110v, I tried, and used a lot, AHP Alpha tig201xd. Yup, Chinese, but I can easily pick it up by hand.
It welds almost ss good as my Synchrowave. |
Lo-Fi Version | Time is now: 28th May 2024 - 02:57 AM |
