THe Ulimate Humiliation??, Tow Truck Involved |
greenie |
Jul 24 2005, 10:35 AM
Senior Member Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest |
So we get back from the John Walker Swap meet with by bounty, driven about 50 miles,the car running perfectly. Start it with no problem, drive to the gas station,off & on again,home etc, running great.
We decide to go to the British car show at the community college. Park it for about two hours come back it won't start. Start checking things , fuel pump relay clicking, fuel pump running ,pressure to hose (but didn't pull a line ). Getting spark to plugs, car will run with starter fluid. I don't feel my injectors pulsing when cranking, get my multimeter out & getting 12 volts at the 4 plug connector on the relay board. No voltage measured at the little injector connection while cranking engine WTF?? Probably two hundred British, Lucas, electric equipped cars fire up & driveoff. I wait for the sun to go down & call AAA, my self esteem is shot! Help please. Greenie |
skline |
Jul 24 2005, 10:38 AM
That is just too funny, I am sorry you had to endure that kind of humiliation, check your trigger points, that would be my first guess.
Joe Bob |
Jul 24 2005, 10:45 AM
This should be in the FAQ......describe "won't start"......
1) Turn key, nothing? 2) Turn key, click? 3) Turn key, click and starter turns over engine? 1) could be ignition switch, relay for seatbelt buzzer uner seat (some models), hot start problem with starter....BANG on solenoid.... 2) Hot start problem, loose ground on battery or trans strap, low battery, etc... 3) fuel pump, trigger points, etc.... Feel free to add.....suggest admin put in FAQ...... |
Bruce Allert |
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
I'm on my 4th tow (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Check the wire to the AAR. If it''s grounded it will cause problems. Also the CHT might be unplugged. Won't even start if it's that. good luck ........b |
brp914 |
Jul 24 2005, 10:52 AM
Unregistered |
injector trigger? to test: pull connector from distrib. put ohm meter btwn ctr and outter terminals. turn engine and look for open and close circuit.
neo914-6 |
Jul 24 2005, 11:35 AM
waiting for the sun to go down was good but did they hear you crank it and make strained faces? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I did that once at Laguna Seca but it was because I fell asleep drunk and loaded and then lost my keys. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
greenie |
Jul 24 2005, 02:58 PM
A big thanks!
Popped the distributor cap off, the contacts looked a little carboned, so I used a little fine sand paper to clean & what daya know.. she fired right up. I guess it's time for new cap plugs & points. I'm not the greatest mechanic so I really don't fully understand the relationship of what I did to " no voltage to the injectors. Greenie |
SGB |
Jul 24 2005, 04:03 PM
I think what he meant was "too high, too low, or incorrect 'spleen'-retriculation" That shouldn't be left uncorrected. It can lead to hardening of the arteries and its associated condition of erectile disfunctiion. I really have probably said too much already.
redshift |
Jul 24 2005, 04:05 PM
Seagrave |
Jul 24 2005, 07:41 PM
Gutenfest Touring Society Group: Members Posts: 197 Joined: 29-July 03 From: Beaverton, OR Member No.: 963 |
I know how you feel. I've had to be towed twice in the last 18 months. Both times for fuel pump relays. The first time was at my house (shown here) and they replaced a relay. The second time (two weeks ago) was at work. Replaced another relay and some fuses but they think the problem (which is intermittent) may be a short in the board itself. Problem is finding another. They're looking. Thank goodness for Hagerty. Sign me, a former British car owner (many years ago) who never had any electrical problems...but enough from every other component. The 914 has been a very reliable car overall, especially considering its age.
tat2dphreak |
Jul 24 2005, 07:52 PM
get a compufire or pertronix... damn points are a bitch! |
rhodyguy |
Jul 24 2005, 11:48 PM
sp wires too if you've never replaced them.
k |
greenie |
Jul 28 2005, 11:44 AM
So I thought it was fixed but........ drove to the store Sunday morning running great! Come out it won't start again
"fuck a duck"! I refuse to call AAA again within a 12 hr period. Call my wife to bring the SUV & tow rope, drag it home. Monday I order up new points,cap ,rotor cond. plug wires & the mystery trigger points from Pelican. You guys talk about these trigger points but I could never figure out where or what they are. I now know. Attached image(s) |
balljoint |
Jul 28 2005, 11:50 AM
While my car is still up on jackstands "cough, cough", and I am on a road trip with my wife in my truck, I often point out to her where on the trip the 914 would break down and I would have to call CAA, and how long we would have to wait, and how we will wish we had brought some snacks and some pop (soda). I am trying to get her ready for the inevitable. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Hopefully your tune-up will solve all of your problems. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
greenie |
Jul 28 2005, 11:54 AM
So we pull the destributor put in all the new stuff (including coil), set the dwell /timing perfect last night.
WE had to start it the 1st time with starter fluid .. It has never ran better.... for the 1st time I have to open up my idle screw to keep it running. Normally it's cranked all the way down & it still would idle @ 1200. The little bit of "popping is gone" Note to newbies "it take about 3 seconds to melt the green condensor wire when hooked up wrong " We start & stop the engine a least 10 times LIFE is GOOD! This morning before work I hop in just to hear it one more time. "NO START AGAIN" I guess I start looking a fuel pressure now huh?? I know it will start with Fluid, once it gets going it runs like a champ. [ Attached image(s) |
greenie |
Jul 28 2005, 11:57 AM
My wife refuses to get in the car with me. I tell her it just needs a few bugs worked out but she is a little leery.
She still hasn't quite got over the gas leak episode. |
jhadler |
Jul 28 2005, 12:05 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Check to make sure the CHT is plugged in and that the connection is sound. A loose CHT connection can easilly give you fits. I know it did to me....
-Josh2 |
lapuwali |
Jul 28 2005, 12:23 PM
It it starts with starter fluid, then always keeps running, then I'd guess it's part of the cold start system.
There's a connection on the relay board that "tells" the ECU that you're cranking. There's ANOTHER connection on the relay board that activates the thermo-time switch, which runs the cold-start injector. Note that "cold" in this context means "below 90dF engine temp". I'd guess your cold start injector isn't firing, so you're mixture at start time is way too lean. If the connection at the relay board is bad, then the ECU also won't see the "cranking " signal, which also richens up the mixture. You need a pretty rich mixture to get most air-cooled engines to light when cold. When "half-cold", like after sitting for an hour or so, starting is usually the most difficult. If, after starting and running for awhile, if you shut off and start it again right away, does it fire OK? In any case, look at my blog and/or the Haynes manual, and trace the relay board connections, esp at the 4-pin connector (relay board to ECU) and the 12-pin connector (relay board to engine). Clean all of these connections with alcohol and/or sandpaper. Intermittent connections here can cause all kinds of flakiness. |
balljoint |
Jul 28 2005, 12:39 PM
To clarify. Use Isopropyl Alcohol to clean (or 180 proof Rum) OR use fine grit sandpaper OR have a beer AND clean with sandpaper. Do not try to clean anything with beer. Unless you get mustard on your shirt at the ballpark. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
greenie |
Jul 28 2005, 02:14 PM
Good advice Mr Asshole ( or is it Mr Lupiwali ?) & Mr Ball Joint I'll give it a go tonight.
I'll also check the CHT Mr Jhadler. This is starting to get a little annoying. Greenie |
Lo-Fi Version | Time is now: 16th May 2024 - 04:35 PM |
