Ignition Switch, '73. Help with removal. |
seanpaulmc |
Jul 24 2021, 06:21 PM
Member Group: Members Posts: 303 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Hello World -
I'm trying to R&R the ignition switch. And, I need a little help. I've got the ignition lock tumbler out but cannot seem to get the holder out in order to get at the ignition switch below it. Here's a look at where I'm at. 1973 model year Knee pad is off Allen bolt is out I also have a replacement steering column switch to put in and plan to rekey some lock cylinders while this is all apart. Is there anything else that need to get done at this time? Thank you, Sean |
914Sixer |
Jul 24 2021, 08:01 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put the lock back in. Turn ignition on to release the column locking. Should be clear and pull the whole assembly out in one piece. Replace electrical portion before replacing switch.
Side note your switch is 75-76 because of the black plastic cap and the roller cam entry. |
seanpaulmc |
Jul 25 2021, 04:08 PM
Put the lock back in. Turn ignition on to release the column locking. Should be clear and pull the whole assembly out in one piece. Replace electrical portion before replacing switch. Side note your switch is 75-76 because of the black plastic cap and the roller cam entry. Thank you, @914Sixer! Both comments very helpful. That switch housing was stuck in there pretty good. I had to use an 0.008” feeler gage to ensure the pawl was retracted and vice grips to get a solid grip to pull with and it eventually came out. Years of gunk kept it solidly in place. And thanks for the heads up on the late model key tumbler. It certainly explains why the ignition key doesn’t work anything else. More proof I have a parts car. (IMG:style_emoticons/default/headbang.gif) Cheers, Sean |
Lo-Fi Version | Time is now: 25th May 2024 - 07:28 PM |
