Green wire purpose |
dt4 |
Jul 31 2021, 10:02 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
Hi
I have a green wire coming off the wiring loom under the battery tray Could some one let me know what this is for please |
JeffBowlsby |
Jul 31 2021, 10:17 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its actually a green/black stripe wire. It is the connection point on th main harness for an optional oil temp sensor at the bottom of the engine case, which feeds a signal to the optional oil temp gauge in the center console of 1973-76 cars.
dt4 |
Jul 31 2021, 10:45 AM
Its actually a green/black stripe wire. It is the connection point on th main harness for an optional oil temp sensor at the bottom of the engine case, which feeds a signal to the optional oil temp gauge in the center console of 1973-76 cars. marvellous, thanks Jeff, I have the loose end of a wire coming off the oil temperature sensor and the gauge in the centre console I'll connect the 2 and see how it goes |
914Sixer |
Jul 31 2021, 10:58 AM
914 Guru Group: Members Posts: 8,883 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Probably disconnected because the wire from the sender to the plug is bad causing bad oil temp reading. Jeff sells replacement wire that is encased to prevent problem.
930cabman |
Aug 17 2021, 07:03 AM
Advanced Member Group: Members Posts: 3,065 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Its actually a green/black stripe wire. It is the connection point on th main harness for an optional oil temp sensor at the bottom of the engine case, which feeds a signal to the optional oil temp gauge in the center console of 1973-76 cars. marvellous, thanks Jeff, I have the loose end of a wire coming off the oil temperature sensor and the gauge in the centre console I'll connect the 2 and see how it goes Did connecting the dots get your oil temp gauge working? |
Lo-Fi Version | Time is now: 19th May 2024 - 06:59 AM |
