Distributor drive shim ? where to get one ?, part search |
TRE Cup |
Aug 9 2021, 01:39 PM
Member Group: Members Posts: 80 Joined: 1-March 05 From: North Hollywood, CA Member No.: 3,690 |
Hello fellow Teeners Every year or so, we get to rebuild a 914 engine. This time we are doing a 1.7 to 2 liter rebuild with carbs and 123 dizzy. The original dizzy did not have the drive shim that goes between the shaft and engine case. Can someone help with this? The dealer no longer carries it and I'm at a loss if there is an equivalent VW part number so we can source a new or used on Thanks for the help Dave tremotorsports@gmail.com |
iankarr |
Aug 10 2021, 08:14 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,479 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The 123 needs a spacer to sit tight against the case...are your referring to that? If so, 123 sells em.
GregAmy |
Aug 10 2021, 08:46 AM
Advanced Member Group: Members Posts: 2,309 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
There's a washer at the bottom of the disty drive, part number 021 105 235. Spring on top is 111 105 233
I checked my stash and found the drive, but no washer or spring. |
cary |
Aug 10 2021, 08:54 AM
Lo-Fi Version | Time is now: 27th May 2024 - 02:47 PM |
