Would an engine run..., with the injector connectors crossed? |
BMartin914 |
Jul 25 2005, 07:48 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Pulled my harness this weekend (74 2.0 d-jet) and tagged all connections in the process of removal. As I was cleaning it up and doing some repairs I noticed that the grey boots on the injectors (black ones are missing) were in back. Should they not be in front? The motor ran before, but was having some problems. How big of a problem could this create?
This is the first time I have had the harness out, but I am sure that it has been out before. Makes me wonder. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Cap'n Krusty |
Jul 25 2005, 08:16 AM
It'll run. The Cap'n
Bruce Allert |
Jul 25 2005, 09:36 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
I'd read somewhere that you can remember where they go with the saying, "Black in back". If you have the harness off use a meter & do a continuity test from the ECU connector block to each connector I think the bird board has a list of each connector as it is connected by number to the ECU block. That way you can see which connection end goes to where. I've done it a couple times with mine. It'll also tell you if you have a broken wire.
.....b |
Dr Evil |
Jul 25 2005, 09:57 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So long as they are on the right side, you will have no problem. IIRC, they fire in groups of two: L and R so if you swap your front and back it should be a non issue.
Am I mistaken? |
goose2 |
Jul 25 2005, 10:31 AM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Actually they fire in groups of 2 diagonally opposed cylinders....this is always a good clue when diagnosing trigger point problems. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:20 AM |
