Windsheild Trim Clips, All but 3 work,,,,,,,ugh |
ctc911ctc |
Aug 15 2021, 07:13 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74, 2.0
All, I am at the end of the restoration - adjusted the clutch cable yesterday and the nut on the 180-wheel was missing! Yikes - put a new nut with a wavy lock washer WITH some lock tight.........does anyone else think it is weird to have that wheel out in the wild without a cover? HOWEVER, that is not my problem today. I put the new trim on the windshield and on the passenger lower corner the three clips (two on the bottom and one on the vertical will not click in. Not sure what to do. If I press really hard it seems that one of them starts to seat and then the clip does not hold. So I am at the cross roads, remove the winshield and new clips OR get out the Two-Part and piss someone off in the future........... (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:16 PM |
