Fuel issue., Low voltage? |
Tjmrfe |
Aug 29 2021, 03:03 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Hey all,
So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo, Took my battery to the pump, + to + and - to - my pump works just fine…. But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts? thanks as always. |
Tjmrfe |
Aug 31 2021, 01:51 PM
Hey all, So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo, Took my battery to the pump, + to + and - to - my pump works just fine…. But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts? thanks as always. |
jrmdir |
Aug 31 2021, 02:34 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hey all, So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo, Took my battery to the pump, + to + and - to - my pump works just fine…. But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts? thanks as always. Did you try swapping out the relay with one of the others to see if anything changes? Ron EDIT: Swapping the usual relays doesn't apply to 1.8 I guess. See this post and check out the "dual relay" http://forums.pelicanparts.com/porsche-914...-fuel-pump.html |
Tjmrfe |
Aug 31 2021, 04:51 PM
Hey all, So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo, Took my battery to the pump, + to + and - to - my pump works just fine…. But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts? thanks as always. Did you try swapping out the relay with one of the others to see if anything changes? No I but I do have another dual relay, I’ll give that a shot, Thanks… Ron EDIT: Swapping the usual relays doesn't apply to 1.8 I guess. See this post and check out the "dual relay" http://forums.pelicanparts.com/porsche-914...-fuel-pump.html |
Tjmrfe |
Aug 31 2021, 07:12 PM
Hey all, So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo, Took my battery to the pump, + to + and - to - my pump works just fine…. But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts? thanks as always. Did you try swapping out the relay with one of the others to see if anything changes? No I but I do have another dual relay, I’ll give that a shot, Thanks… Ron EDIT: Swapping the usual relays doesn't apply to 1.8 I guess. See this post and check out the "dual relay" http://forums.pelicanparts.com/porsche-914...-fuel-pump.html Thank you, turned out that Pelican article helped, the dual really was the fault, it had been an old one. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:03 PM |
