Hey all,
So, my motor is (75’ 1.8 stock EFI) back in the car, with assistance from a very helpful 914 world member! (thank you again Rory) and it won’t start…first I figure I’ll check the basic stuff, fuel? my pump doesn’t make any noise…so I Put my meter on the pump leads, while turning key, and I opened flap on intake… I get 9vdc….so next I go to pin 88d- 9vdc. At pin 86 I’m getting 9vdc….at pin 88y I’m getting 12vdc…soooooo,
Took my battery to the pump, + to + and - to - my pump works just fine….
But somehow I’m loosing 2 Volts along the way? Any one else had something like this? Doesn’t seem to make sense, I’m getting a voltage drop? Is there another stop along the way that the pump feed would loose that 2 volts?
thanks as always.
