heater lever wiring |
friethmiller |
Sep 1 2021, 09:51 AM
Senior Member Group: Members Posts: 501 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I've got the opposite problem of the Aux Motor being on non-stop once I connect the battery. Even unplugged the wire going to the heat lever and it keeps running. Is this an indicator of a malfunctioning relay?
NARP74 |
Sep 1 2021, 09:59 AM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Must be shorted to ground somewhere after the lever.
friethmiller |
Sep 1 2021, 10:10 AM
dt4 |
Sep 1 2021, 12:28 PM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
turned out that the relay was kaput
I swapped with a headlight relay to prove the point then used a spare from my stock heater blower now working well thank you all for the help and advice (IMG:style_emoticons/default/beerchug.gif) |
Quinn Moore |
Sep 1 2021, 12:30 PM
Qmoore Group: Members Posts: 108 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
I've got the opposite problem of the Aux Motor being on non-stop once I connect the battery. Even unplugged the wire going to the heat lever and it keeps running. Is this an indicator of a malfunctioning relay? Same problem as well, I noticed however; if I put a little pressure on the lever to the left (not fwd or backwards) (sideways). Fan motor stopped. May be worn out spacer?....I have to take it out this weekend and take a look. See if it can just be cleaned. QM |
NARP74 |
Sep 1 2021, 01:54 PM
turned out that the relay was kaput I swapped with a headlight relay to prove the point then used a spare from my stock heater blower now working well thank you all for the help and advice (IMG:style_emoticons/default/beerchug.gif) On to the next problem! |
914_teener |
Sep 1 2021, 04:14 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
turned out that the relay was kaput I swapped with a headlight relay to prove the point then used a spare from my stock heater blower now working well thank you all for the help and advice (IMG:style_emoticons/default/beerchug.gif) This is a switched ground. IIRC correctly the relay is the same for the fuel pump so......??? Car wasn't running. Been a long time but I remember this circuit well as the trace on the board (regulator plate) was the problem I encountered. What a tracing testing nightmare that was. Probably why I remember it. Glad you got it working by just pulling the relay. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:02 PM |
