Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
Shivers |
Sep 5 2021, 08:25 AM
Senior Member Group: Members Posts: 2,375 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Once, before I threw my points as far as I could, I bought a set of points and a condenser. I put them in and it did what you are experiencing with yours. The condenser was bad enough to keep welding the points together for a fraction of a second. Knocking the points out of adjustment. Best day in my car was that cold morning, after putting in electronic ignition. I turned the key and it fired off on the second rotation.
Lo-Fi Version | Time is now: 17th May 2024 - 12:05 AM |
