Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
bbrock |
Sep 5 2021, 02:36 PM
As I said in the first post, I have a Pertronix III. It does not work on two of three dizzies I've tried it on. If anyone is successfully running a Pertronix Ignitor III on an SVDA or DVDA dizzy, I'd like to hear about it. Oh yes, I also am running the Pertronix plug wires. IMO, the Ignitor III is simply not ready for prime time. Too many people reporting the same results I had.
Right now I'd just like a solution that will hold the tune for a couple more months of driving. Then I'll dig into the microsquirt which will include installing a modern coil pack. One option is to just switch back to the 050 with Pertronix in it. That works well enough but doesn't provide the silky smooth acceleration I'm getting with the properly tuned OE distributor. The other is to try another set of points and hope they behave. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:10 PM |
