Gawd I Hate Points, Won't keep a tune |
bbrock |
Sep 4 2021, 08:09 PM
Quick background. Engine is a rebuilt 2L with Elgin cam and Weber 40IDFs. I bought a Pertronix Ignitor 3 to avoid having to mess with points but I could only get it to work well with a NOS Bosch 050 distributor. It runs rough with a brand new Bosch clone SVDA and the OE dizzy. However, the engine runs best with the OE DVDA distributor so I'm running that with points.
The problem is that I've had to adjust dwell and timing 3 times in only 1,000 miles of driving. Each time the dwell creeps up until the engine starts spitting and farting and is a bit hard to start when warm. Readjusting the dwell and timing gets it running like a top again. So (IMG:style_emoticons/default/WTF.gif) Only thing I can think is that the phenolic block on the points is wearing crazy fast. I lubed the cam and block with high temp slicone grease and I can feel it is still on there. Did I just get a shitty set of points? |
Superhawk996 |
Sep 6 2021, 12:30 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/headbang.gif) Man. This is crazy. (IMG:style_emoticons/default/idea.gif)
So OK on the coil resistance with internal ballast. No burning. Check. How about the screws that hold in the points plate to the distributor body? All tight? What I'd really love is to see it curved on an old fashion distributor curve machine and/or hook up an O-scope to it. What a mystery! Right guy is on the case though! (IMG:style_emoticons/default/aktion035.gif) One more thought -- do you have the spring in there that goes between the distributor drive shaft (in engine case) and the distributor body / drive cog itself? That spring helps pre-load the drive shaft gear to the crank gear. If not pre-loaded, you would get some random dwell variance depening on gear mesh. Really stretching on theories here . . . .. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 AM |
